Home Forums Printing Discussions Roland Printers Corel12 & Roland Colorrip
  • Corel12 & Roland Colorrip
    Posted by Shane Drew on 21 May 2005 at 11:05
    I have a problem that has got me stumped.
    Up until recently I have been using Corel 10 to do my die cut of stickers within colour rip on the Roland.
    Pretty easy stuff, just add a colour to the pallet, call it CutPath, and all is sweet.
    Problem is that I have recently purchased and installed Corel 12, did the same thing, but when I sent it to the printer, it does not recognise the CutPath, and will not die cut.
    Anyone have this problem?, or know that answer?
    I have gone back to Corel 10 for anything that needs cutting, but it sort of defeats the purpose of having version 12 😥
    Any help would be appreciated.
    Shane
    Chris Wool replied 20 years, 4 months ago 7 Members · 10 Replies
  • 10 Replies
  • Paul Goodwin
    21 May 2005 at 16:21
    Hi Shane
    i’m using 12 here and i set mine to a cut path, use it as a hairline and it’s fine ?
    21 May 2005 at 16:40
    SHANE EVERY NOW AND AGAIN MINE DOES NOT SAVE THE CUTPATH CORRECTLY AND HAVE ENDED UP with CutPath1 – 2 – 3 – etc.
    which colour rip will not cut but print it
    if colour rip prints it then its not named correctly for whot ever reason
    21 May 2005 at 18:25
    corel 10 may have a different colour palette to corel 12 and in corel 12 the application programming language did change a little.
    Check website for CutPath (?) and see if there is a revision for Corel 12, cant think of anything else it could be.
    21 May 2005 at 20:36
    Thanks very much everyone
    I’ll do the process again and see how I go, although I am pretty sure I did it right the first time. Of course I could be wrong… I am a married male afterall 😮
    I’ll check the wastach website for an update too, appreciate everyones help (yet again) 😛
    Shane
  • Peter Shaw
    22 May 2005 at 06:00
    I’ve never had a problem with this at all, CutPath is always recognised from Corel 12.
    Can I suggest you check the Wasatch/Colorip help screens where there is a section on setting up the CutPath for various types of software. It may need to be defined in a particular user area
  • David Marsh
    20 July 2005 at 21:51
    quote dsi:
    Shane
    I may be wrong but I’m pretty sure that the user defined colour in Corel 12 is ‘CutContour’
    Try it 🙂
  • Mark Shipley
    21 July 2005 at 11:44
    Hi Shane,
    Have you specified your ‘CutPath’ colour as one of the spot colours? If you’ve renamed a normal cmyk colour as ‘CutPath’ it won’t work.
    Also on another note don’t forget to output any eps’s from Corel 12 as PostScript 3 otherwise you’ll end up with many problems including truncated prints.
    Mark
    21 July 2005 at 13:19
    Thanks Tan Man. I checked my users manual on the colour rip tonight, and it is definately CutPath. if I still can’t get it to owrk, I’ll certainly give it a try tho 😥
    Thanks Mark. Thinking about your suggestion, you may have pointed me in the right direction here. I’ll check it out at work tomorrow (its 11:20pm here now) , but I suspect I did rename a cmyk colour, as that is the palette I default to on my system.
    I’ll let you know.
    i appreciate everyones time on this.
    Shane
  • David Marsh
    21 July 2005 at 13:37
    quote dsi:
    I’ll let you know.
    Shane
    I’ve got my colour set up as a spot colour (a nice Orange 😉 ), that seems certain to be the problem. It’s definately called CutContour though, although I’ve not tried it as CutPath.
    21 July 2005 at 13:55
    i thought it was the rip that was fussy about the name of the path colour and it could be any colour as long as it was called CutPath – only had a problem when within the rip the “Process Cutting Paths” was unchecked by accident
