Home Forums Software Discussions Flexi Sign Software Contour cut bitmap image in FlexiSign?
  • Contour cut bitmap image in FlexiSign?
    Posted by erik on 12 February 2009 at 17:20
    Hello…
    I use FlexiSign with Roland SC-500.
    It cut’s perfect contour around vector objects, like logos,.. etc
    Does anybody know how to cut contour around bitmap image (not rectanular). I have some car photos on white surface and I want to cut
    contour around.
    Any idea?
    Thanks,
    Eric
    Lorraine Clinch replied 16 years, 7 months ago 5 Members · 11 Replies
  • 11 Replies
  • Kevin Flowers
    12 February 2009 at 17:41
    ensure you have the bitmap tool bar up (right click tool bar the tick bitmap tool bar). Use the magic wand to select the white area then go to Bitmap menu 7 convert marquee to shape. You can the apply the contour cut to the shape, separate the contour then delete the shape. You can also use the shape to mask the bitmap & contour cut that way.
    Hope it helps
  • erik
    12 February 2009 at 18:26
    Thank you for advice, Kevin…
    I’ll try 🙂
  • Dean Poulter
    3 June 2009 at 19:44
    hi Erik
    I have just brought a SC 500 and can not get it to print very well at all with flexi, so was wondering where u got your profiles from
    Cheers Dean
  • erik
    3 June 2009 at 20:52
    they came with printer 🙂
    do you need it?
  • Dean Poulter
    3 June 2009 at 21:11
    yes please that would be much appreciated
    Many Thanks Dean
  • erik
    5 June 2009 at 13:16
    write down your mail…
  • Dean Poulter
    5 June 2009 at 13:37
    mod-edit please read board rules
    One again thank you for this
    Dean
  • Dean Poulter
    5 June 2009 at 19:16
    Hi Erik,
    It won’t let me put my in details for you to be able to email me. How do i get around this?
    5 June 2009 at 20:17
    you need to be a paying member to contact others
    Have a look at the membership options, and the board rules.
  • Dean Poulter
    5 June 2009 at 22:26
    what membership should i need then
  • Lorraine Clinch
    5 June 2009 at 23:15
    Hi Dean
    Look at the various levels available, consider what you would like to have available to you, and affordability.
    Although you can’t see them as a non-paid up member, the amount of learning resources available to Gold-plus members is amazing. It’s not just a load of old drivel, for newish start-ups and ‘proper’ Sign-makers working alone this forum is (from experience) a real life-saver, and a business saver too, because of the support you will get as a proper member.
    If you are making purchases on vinyl and boards then UKSG membership will give discounts on purchases with certain suppliers. You also get to send & receive PM’s, see other’s www sites and email addys.
    UKSG is designed for real communication between serious signmakers.
    I had questions when I first found this site, and asked what I would get for my money, got told the same as you, ie, just ‘do it’. I did, signed up for UKSG and have never for a second regretted it.
    Hope this makes things clearer for you, and anyone else hovering on the sidelines!
    Lorraine
