Home Forums Vinyl Cutter Discussions Roland Cutters Communication breakdown between cutter and PC
  • Communication breakdown between cutter and PC
    Posted by John & Dawn Roddick on 17 July 2011 at 17:06
    Hi folks. I have a Roland CX24 which we have run for years from our PC using CorelDraw X3 and Signtools for software. Over the last couple of weeks, I have experienced frequent problems whereby there appears to be no communication between the PC and the cutter. I had changed to a USB-parallel cable a few months ago and thought that may be the problem so reverted to the old parallel cable. It made no difference but after changing the settings for what seemed like hours, it worked. The next day, there was no communication again. Eventually I got it going again but have the same problem today.
    Does anyone have a suggestion for fixing this or if there free trial software I can try with X3 to find out whether the problem is with Signtools or the PC/cutter.
    Dawn
    John & Dawn Roddick replied 14 years, 5 months ago 8 Members · 15 Replies
  • 15 Replies
    17 July 2011 at 18:41
    I had a similar problem using winplot and corel 12. In the end I downloaded the newest winplot which removed the fault. Like yourself I’d used the original combo for several years, I recon it was in incompatible xp update.
    I’d imagine you’ve already re done the software though?
    Hugh
    17 July 2011 at 18:55
    i have created a file that you can send to the plotter to test, do you know how to send a file from a dos window.
    the idea being to see if the port and plotter are ok removing the corel sign prog possibilities
  • Tim Painter
    17 July 2011 at 19:10
    You can cut direct from corel using the roland print driver no 3rd party plug in. Set lines to 0.01 point.
  • John & Dawn Roddick
    17 July 2011 at 19:34
    Thanks for the advice. I have uninstalled and reinstalled the software but that didn’t help
    Don’t know how to send from DOS, but will try Tim’s suggestion
    19 July 2011 at 17:58
    Okay, I’ve tried Tim’s suggestion and still can’t get anything to cut. It did however cause the bladeholder to move from one side of the cutter to the other, so there is some communication between the cutter and PC.
    Does anyone else have suggestions on how to sort this out?
    19 July 2011 at 18:05
    quote :
    normally that would be a miss match between the corel page and driver page settings
    19 July 2011 at 18:46
    What action would I need to take to rectify that Chris?
  • Ian Pople
    19 July 2011 at 19:14
    Can you not just use the Roland plug in for corel and test the cutter from that.
    Ian
    19 July 2011 at 19:53
    I’ve had a look online for the plugin and can only see Pirate links
  • Tim Painter
    19 July 2011 at 21:26
    Will it cut the built in test where it cuts CAMM1 ?
    Have you tried a new cable?
  • Earl Smith
    20 July 2011 at 08:15
    http://download.rolanddg.jp/en/cutting.html#gx24
    Maybe somewhere on this site you will find the legit drivers etc that you need.
    Earl
    21 July 2011 at 16:52
    still no further forward with this. Any other ideas much appreciated
    21 July 2011 at 18:05
    The only suggestion I can think of is to try a system restore to an earlier date before the problem started. ( Go to windows help and type "restore" in the search function for more information)
  • John Hughes
    21 July 2011 at 18:28
    I had the same problem quite a few years ago with a Roland – could not work it out. In the end I took the plotter to another sign maker. We setup on his PC and worked no problem.
    Got it back to my place and was all ok – sort of rebooted it self.
    22 July 2011 at 06:34
    Thanks folks. I will try again today
