Home › Forums › Printing Discussions › General Printing Topics › Clear Lacquer
Clear Lacquer
Posted by druiddesigns on 1 March 2004 at 17:25hi
i am in need of some help, i am after buying some clear lacquer to put onto my Versa Camm prints to aid in their outdoor life.
I am wondreing is the Lacquer i got the right one….
It is Clear Lacquer with Cellulose- high gloss.It is made by Simoniz…
I have a job to finish tonight and they need to have extra protection…
Help
Richie
Jim Clough replied 21 years, 9 months ago 10 Members · 18 Replies -
Try a test first , see that the solvents dont dissolve the inks.
Spray and cook will do in a pinch btw. -
Where can i source frog juice.(in a Hurry)
I tried the clear lacquer and it seems to be ok when left to dry, but if ai touch it when wet it will damage prints !!!!!!!!!!!!!!!!!!!!!!!!
Richie
VICTORY DO IT BUT I AM SURE I HEARD SOMEONE SAYING CHERWEL SIGN SUPPLIES DO IT TOO.. (I COULD BE WRONG ON THAT THOUGH) 😀
why not just cover them in clear vinyl using a felt squeegee?
If you use solvent over solvent you are heading for trouble, use an acylic laquer i have used Krylon with good results (B&Q) just don’t build up to much in one go
Kevin
yep kev your probably right there mate. 😉
i never thought about that! i use frog juice on my thermal prints.. never gave the solvent thing a thought when replying.. 😕i still think covering in clear vinyl is the safest way to go & gives a great finish 😉
Yeah, they are right mate, I would avoid using anything with that sort of strength of solvent in it. It will almost certainly have a bad effect on the properties of the vinyl too. You are best to use an acrylic lacquer as Kevin said or Frog juice from Victory 01246 570570.
Nigel
im confused now.. 😕 i thought kev was pointing out to me that forgjuice was a solvent based spray. to be honest i have never taken note/read the can.. i just use it on my thermal prints.. somebody put me out my misery, please! 😆 😆 😆
Frog Juice should work on all digital prints but a taste piece would be required as always.
Rob, I think what Kev meant was that using an agressive solvent based clear like Richie’s cellulose based lacquer over digi prints was asking for problems.
As far as I know frog juice is based on a much less agressive solvent like meths rather than cellulose thinners. I’m no chemist but you could read up on it here http://www.superfrog.com/frogjuice2.html 🙂Don’t know if that has cleared your confusion at all though ???
Nigel
Seriously , try spray and cook on output from the Versacam , its the “secret ingredient” here. It actually makes the graphic very resistant to scratches etc (most likely pledge furniture polish with silicon would do the same- will give it a try today and report back)
To do it right , a cold pressure overlam is required. Ask your local urethane coating guys what they recommend , there are some really nice non solvent based spray/brush products out there that are cheap , easy to apply , uv stable and flexible.
PS , cold overlams are a lot cheaper than clear vinyl and have a far better optical quality glue even if you hand apply. Use a soft matt which is almost gloss but will hide any imperfections and wont make the graphic reflective to the extreme. -
Hi all
Lads thank very much for tall your help and advice , am on my way to a job down the country,
When i get back i will look into this futher,
Talk to ye soon
Richie
Thanks Again
Cherwell do do frog juice i saw it on the shelf the other week
richie, as far as i know, osullivan print supplies in dublin sell
frog juice, they do a next day delivery as well, hope this helps 😉 eddie -
hi all
thanks for all the help and info.
was at the sign show for two days , feet killing me, at the airport, a three and a half hour drive when i arrive in dublin at 11.10
talk to you all soon
Richie
There is an alternative to frog juice, it comes in various formats Clearjet and Clearshield. One is solvent based, the other is water based. The supplier is Alumaframe. tel: 01787 474 300 They do a free sampler pot, I have one to try on sublimation print but have not as yet tried it out. They also do it in gloss semi-gloss and matt.
Jim
