Home Forums Sign Making Discussions General Sign Topics Cast Aluminium letters – has anyone used these or know of supplier
  • Cast Aluminium letters – has anyone used these or know of supplier
    Posted by Myles Brewer on 10 October 2017 at 11:37
    Hi All,
    Just wondering does anyone have any experience or knowledge about cast aluminium letters?
    If so what are pros & cons for them? Limitations on size shape etc.?
    I have a job to quote for & think they may possibly fit the bill. There is a variety of letter size required from 750mm height with 40mm stroke to same height with 135mm stroke. Also a logo which is approx 1000 x 1600mm.
    It all needs to be 3D but flush mounted & I think that cast aluminium could give a bit more depth than just flat cut sheet aluminium. All need to be colour matched to a pantone ref if possible.
    Which finish would be more durable, paint or powder coating?
    Some of the lettering will be at below eye level outdoors so needs to be able to withstand the odd bystander potentially leaning against them along with the usual weather battering. This is the main reason I’m thinking of cast as opposed to built up, along with the impression I’ve got that it may be a more economical option? (probably incorrect!!)
    Andy Thorne replied 8 years, 2 months ago 2 Members · 12 Replies
  • 12 Replies
  • Andy Thorne
    10 October 2017 at 14:18
    Wards Of Bristol ( http://www.ward-signs.co.uk/product/lettering/ ) would be the kiddies you want here although not sure they would be cheaper than built ups. However, if you want a "prism" 3d effect then they may well be. (If yours is a size and style they have a mould for!).
    Hope that may (but possibly may not!) help…..
  • Myles Brewer
    10 October 2017 at 14:25
    Thanks for the link Andy, I’ll give them a shout.
    They will actually all be flat faced not prismatic & it’s a brand logo & lettering so has to be a specific font in different weights. It would definitely be a custom job & not off the shelf but I’ll give them a bell anyway.
    I may well end up going with built up yet, but had stumbled across cast aluminium & it seems on the face of it to be a good alternative option until I find out otherwise.
  • Andy Thorne
    10 October 2017 at 14:58
    You could always just rout out of some 10, 20 or 25mm thick acrylic to give you the depth without building up? We do this quite a bit and paint with a two pack (car type paint). Can work out more expensive than built ups if a large piece (due to the cost of the thick acrylic) but on small letters works well. Just another idea to throw in to the mix…. 😆
  • Myles Brewer
    10 October 2017 at 19:44
    I think these would class as large pieces wouldn’t they at 740mm height?
  • Andy Thorne
    11 October 2017 at 12:32
    Possibly, depends if you can "nest" any smaller letters within the logo to save on material?
  • Myles Brewer
    11 October 2017 at 15:49
    Out of interest what size are the acrylic sheets you use? I can do a quick nest here to get a rough idea of how many sheets might be required.
  • Andy Thorne
    11 October 2017 at 15:55
    Hi Myles, usually 3000x1000mm or 2030x1350mm.
  • Myles Brewer
    11 October 2017 at 20:06
    With true shape nesting in Flexi I managed to get it all into 2 full sheets & just over half a third sheet of 2030x1350mm
    with 10mm spacing.
  • Andy Thorne
    12 October 2017 at 09:23
    Hi Myles, unfortunately the rules state that I cannot recommend my companies services so all I can recommend is that you find someone who can rout these for you, affix studs into the rear for flush wall mounting and can get painted with a two pack low bake (as per car repairs) paint to your pantone colour. (which is what we would do)
  • Andy Thorne
    16 October 2017 at 09:27
    Hi Myles, hopefully Chris has forwarded my contact details and look forward to hearing from you to see if we can help.
  • Myles Brewer
    16 October 2017 at 10:22
    Hi Andy,
    Not quite sure what’s happening. I actually tried to pm you & also send email via signboard links on Thursday but presuming you didn’t get them? Maybe check spam? I actually got an email from Chris to say it had been sent to you.
  • Andy Thorne
    16 October 2017 at 11:12
    Hi Myles, yes I did receive your message but it came from Chris and your e-mail was not on there to reply to so asked Chris if he could pass on my contact details. Anyhow my direct e-mail address is at@simplexltd.com so try that…
