Activity Feed › Forums › Sign Making Discussions › Vinyl › carbon fibre effect supplier needed please?
Posted by jason-price on March 5, 2007 at 12:52 pmright guys an gals! need some help! (which goes without saying lol)
am after a printed effect carbon fibre vinyl, metamark do it, but only in a 610 roll, i have two bmw roofs to wrap (apparantly its all the rage!)
so need at least a 1220 wide roll, am i chasing around for nothing?
failing that, will have to print it!!!
any help from anyone would be mucho aprecciated!
(and i have to have two teeth removed later, one being a wisdom toof, so please have pity!)
jas
Ewan Roberts replied 17 years, 1 month ago 11 Members · 15 Replies -
pity yes lots off.
vinyl think i have seen it but may not be high enough quality.
Jason I was about to say Metamark as I’ve used theirs before too …….. dunno if you can get it anywhere in 1220mm wide ? ? ?
but try
thanks marcella, shall have a look at the site!
right off to the dentists, for a bit of pain, and i have to pay for the pleasure!!!
j
I haven’t seen it in 1220. Hexis do a few styles but all 610mm.
jason try victory ….they do it because ive used it but not sure of the size…mabe worth a call …..01246 570570
cheers guys an gals, will check out all the numbers and suppliers yuo gave, thanks all!!!!
jas
(so, got to have one wisdom tooth out, and a root canal done, not bad eh! arghghhhhhhh!)
following sort of in keeping with this post, i need some carbon vinyl, but my usual supplier doesnt have the exact patter i need to match in with existing real carbon fibre material. I found some on the net, but stupidly didnt save the site, now i cant find it again. Its got to be black carbon with the silvery shadowing. and the weave needs to be of the diagonal style, rather than the straight plain chequered look. It has to be this one to match in with the real exposed carbon already on the body work. hope you can help guys, oh and the width doesnt really matter, 610 ideally.
hi matt
i still havent manged to find a width i need, but had a quick meeting with hexis, and they do about 4 different stlyes. maybe one of those wuold be suitable
jas
I just got samples off the companys mentioned here and they all seem to be diferent. Some are quite thick and some are quite thin.I thought it would all be the same as it is all carbon fibre.
Maybe you could do the same -
My local Spandex distributor does it in 610. Its more like a foil so I don’t know how conformable it would be. Only £6 approx per metre too. 😎
Only picture I have of it
ooh yes, that looks like the stuff i need, do u have a contact number for them please??
They’re in Northern Ireland but I can give you the number if you want. I would imagine most Spandex distributors would carry the same stock though
Victory deffo do it in 1220mm wide
http://www.victorydesign.co.uk/categori … -materials
Hope this helps
Dorotape do 1220wide Carbon Effect £16 a meter though. It is cast and has a 5-7 outdoor life span. Done a few car bonnets with it and it’s good stuff. If you ask them they will send you a A4 sample and intro pack of all there other products.
Ewan.
