Home › Forums › Software Discussions › Signlab Software › Cannot print psd files from Signlab 8 VPM
Posted by R.Lamerton on 30 November 2008 at 15:31I’ve opened a psd file in my vpm from photoshop cs3 and all i get when it prints to my versacamm is a smudge of multicolours? 🙁
R.Lamerton replied 17 years ago 2 Members · 6 Replies -
you cant open or import PSD files with vmp, although you can drop them into signlab and send to vpm from there. (Unless its changed on the last build) or just thought, are you using signlab to versacam?
How are you doing it?Peter
quote Peter Normington:you cant open or import PSD files with vmp, although you can drop them into signlab and send to vpm from there. (Unless its changed on the last build) or just thought, are you using signlab to versacam?
I’m on build 6 of Signlab Print & Cut Ver 8 and you can import tif, jpeg, pdf and psd files which you can view in vpm but goes wrong when it comes out of the printer.
What does it look like when you view the raw data?
quote Peter Normington:What does it look like when you view the raw data?
picture looks fine in the viewer pane.
normally what you see in the raw data view is what you get from the print,
have you tried saving the psd as a JPG although once imported to signlab it should be treated as any other picturePeter
quote Peter Normington:normally what you see in the raw data view is what you get from the print,
Thank you, will try tomorrow when i am back at work.
Regards, Robert.
