Home Forums Software Discussions Flexi Sign Software Cannot get a contour cut from colorip through flexi
  • Cannot get a contour cut from colorip through flexi
    Posted by advsign on 8 March 2005 at 20:33
    Made a simple file and placed a contour cut line around the graphic in flexi. Then I exported it to .EPS and opened in colorip. Went to rip-print and the graphic prints but does not cut.
    Any ideas? It use to work for me at one time.
    Thanks,
    Ken
    Jayne Marsh replied 20 years, 9 months ago 3 Members · 3 Replies
  • curt
    30 March 2005 at 07:47
    Not sure what you are asking, you dont give a whole lot of info..
    But it seems you are exporting the art to an outside print and cut RIP..
    Did you make sure both machiines are selected>
    and are the regisration settingd good as well.
    curt
  • Peter Shaw
    30 March 2005 at 18:24
    Make sure your cut line is set up correctly. There are instructions in colorip’s help. It needs to be named CutPath or something similar and the upper/lower case must be exact.
    Sorry if this is a bit vague but I’m at home and don’t have colorip here!!!
  • Jayne Marsh
    4 April 2005 at 17:42
    If you use the contour in effects in Flexisign the colour rip may not recognize it as a cut line (only recognized my flexi family) I think there should be a set colour for the contour cut to be recognized in your rip, you may have to do an contour outline in Flexi and set it to a certain colour and rename it as the previous post said for your rip to see it,
    hope this helps
