Home Forums Sign Making Discussions Vinyl Can you varnish over sign vinyl? Advice please?
  • Can you varnish over sign vinyl? Advice please?
    Posted by Tim Cowlishaw on 21 August 2015 at 17:57
    Customer wants a smooth finish So no raised edges of vinyl
    Can you varnish over it and then sand down recoat for a smooth finish If so what varnish
    Its going outside so thought about yacht varnish
    Thanks in advance
    Gil Johnson replied 10 years, 2 months ago 3 Members · 3 Replies
    21 August 2015 at 18:08
    You can coat it in paint, lacquer, varnish etc. because we have had customers do just that. ie. they sprayed it with clear coat of "something". i have read others having done same too so i doubt you will have much issues.
    however, i think the ingredient of whatever you put over it "might" come into play due to a chemical reaction. easy solution is do some test mate.
    i don’t know what you will be rubbing it down with after the first coat but guessing it will just be something like a flattening paper?
  • Steve Morgan
    22 August 2015 at 07:30
    As Rob has said you can apply lots of paint finishes over vinyl.
    First off I would suggest that you use the thinnest cast material you can get and then take it to a body shop and get it 2 pack laqueur coated but even with that kind of finish which can be loaded up, in my experience, you’ll never completely loose the the edges of the vinyl. Test it first.
  • Gil Johnson
    22 August 2015 at 08:02
    Hi Tim,
    Like Steve says lacquer is the one to go for, standard varnishes are not ‘clear’. Definitely go for a cast vinyl as this sounds like the customer wants it around for a while, a calendered vinyl will have a percentage of shrinkage over time, this will split the lacquer.
    Gil
