Can you print, contour cut and perf cut all in one operation
HI All
I’m playing with perfcut and wondered if possible to contour cut and perf cut at the same time (well one after each other but without stopping the machine if you know what I mean) There are pressure setting in versaworks for perf cut so thought maybe that controls the perf while the cutter controls the contour but it did not work and contour cut both lines at the same pressure (the cutter pressure setting)
Anybody know if this is possible and if not how would you do it?
I’m off to try "return to origin" and then sending a new file (will have to separate Perf and contour files) at a higher pressure.
I know (think) I could use the registration crop marks but want to try avoid the reading crop marks part.
If anybody knows I’m barking up the wrong tree then please tell me to "leaf" it alone 🙄
Warren
