Home › Forums › Software Discussions › Signlab Software › can signlab files be opened in flexisign?
Posted by andy reynolds on 19 August 2006 at 19:29I’m having trouble with sign labs and flexi. I need to know how to open a sign labs file with flexi expert. Can it be done? Do I need to do something else to get flexi to open it? Flexi just won’t import the file, and I need to use flexi to alter it because what I want to do, sign labs won’t do! Unless I’ve totally overlooked something – I need to save the file as a bitmap to e-mail it and as far as I can tell, sign labs can’t (or won’t!) do it.
Someone tell me I’m wrong and there really is an easy way……… 😕
Andy
jdsfw replied 17 years, 1 month ago 9 Members · 18 Replies -
Export it as Illustrator from Signlab, then import into flexi
In Signlab you can use the transform menu to render to bitmap – then save it as a bitmap image. 😀
quote Phill:In Signlab you can use the transform menu to render to bitmap – then save it as a bitmap image. 😀
or in the FILE menu – "EXPORT IMAGE" – same thing (just less control over the resolution)
ok thanks to you all will try every thing 😮
ps thanks for taking the time to help
quote francprint:Judging by the replies it seems no-one here understands the difference between raster and vector. What a joke!
I think you misunderstood the original question.
Andy was asking how to open a signlab file in flexisign in order that he could then go on to convert it to a bitmap using flexisign.
Phill Kneale answered his question most helpfully.
I attempted to help out further by explaining how a bmp file could be created directly from signlab without having to use flexi sign.
David helpfully explained another method by which a bmp file could be created directly from signlab.
Naturally I, and I am sure David and Phil know very well the differences between a vector drawn image and a rendered image. We wouldn’t survive very long in the sign trade if we didn’t know the difference now would we 😛
.Internet troll
"Do not feed the troll" , a troll is someone who comes into an established community such as an online discussion forum, and posts inflammatory, rude, repetitive or offensive messages designed intentionally to annoy or antagonize the existing members or disrupt the flow of discussion, including the personal attack of calling others trolls. Often, trolls assume multiple aliases, or sock puppets. -
ok thanks for all the help but the sign labs program that i am working with
will only let me save as .ipf i need to keep the image the same size so when i email it my mate can cut it the right size on his flexihope you can help
andy 😥
Can you export it from SL as EPS or AI then import it into Flexi?
quote andy reynolds:the sign labs program that i am working with
andy 😥
(?) what version of signlab are you running?
quote andy reynolds:ok thanks for all the help but the sign labs program that i am working with
andy 😥
Maybe you don’t have all of the filters enabled.
Go to FILE, EXPORT and click the FILTER tab (bottom left), select every option – then try saving it out as an AI or EPS – that will maintain the units correctly. ie. if you’re both working in millimetres you’ll be fine.
If you just have a ‘designers’ version of Signlab you’re probably stuffed as you can’t export – just save as signlab files.
Daveps. never seen an *.IPF file extension before. What is it?
thanks david think it is a designers version would it work if i hade a full version of sign labs
quote andy reynolds:thanks david think it is a designers version would it work if i hade a full version of sign labs
Yes, would be totally exportable in loads of different formats.
In ‘a previous life’ I was handed the designer’s version of Signlab and the main company kept the full blown e6 (cheapskates) – was worse than useless so never used it and kept the V5.7 I had been using.
There is NO way to circumvent the export ban, no cut & paste, no nothing to get it to work in a lower version of SL or another program.
quote David Rogers:There is NO way to circumvent the export ban, no cut & paste, no nothing to get it to work in a lower version of SL or another program.
This works on design only Omega so might work SL…print the file to Acrobat Distiller with the graphic "edge filled" (if you don’t have a Adobe Acrobat search Google for PDF factory for free down load) and then import the resulting PDF file into your full working software.
see how you get on
or email me the cdl file and I’ll save it as something else for you.
thanks david that a bit of a ???? looks like i will have to cut the stuff and send it
and ipf ( invisible patterns file ) its clear film for the front of cars vans to stop stone chips scuffs have a look http://www.defendall.com -
oh same as armourfend!!!! You should have said! It CANNOT be converted to another format, this is to ensure that you have to use the manufacturers templates.
Sorry!
Marcella
this is an impasse i am at as well.
venturetape’s ventureshield program gives you an "invisible patterns" branded version of signlab 7.1, which requires the use of a usb dongle and cut codes from the supplier to operate the machinery.
i have installed simultaneously signlab 7.1 and the IP7.1. i can cut freely (not for the purpose of scamming the supplier, but for the purpose of cutting other vinyl and clear product not affiliated with the supplier) with signlab and metered with IP. IP will load any cdl/eps/etc much like signlab, however the .IPF files provided with IP are somehow restricted in signlab. IP will not allow any export, convert, resave, or any other means of retrieving the pattern. with an instance of each open, i’m not even able to copy&paste between them.
my last ditch effort is to "print" the pattern via a generic postscript printer which prints to a local file. after fuddling with the "printer" options, i have landed on EPS2 but there are many print options i’m not understanding.
i have successfully printed an eps from IP and loaded in signlab, however i’m only getting the text labels and no patterns.
does anybody have any experience with this method? i fear this is my only (if any) chance to complete this operation.
thanks in advance, and i hope andy you might get somewhere with this
