Home Forums Software Discussions Signlab Software can multiple copies of signlab be able to run at same time?
  • can multiple copies of signlab be able to run at same time?
    Posted by Gavin MacMillan on 29 March 2007 at 14:09
    Does anyone know if there is a way to have 2 copies of signlab open on the same machine at one time? We used to be able to do it, but after ‘upgrading’ to 7.1 we no longer can – this slows things down LOTS as you now can’t work on a layout while keeping the plotter busy. Well, you can but not as easily!
    G
    Gavin MacMillan replied 18 years, 8 months ago 3 Members · 6 Replies
  • Brian Hays
    29 March 2007 at 14:35
    You need to have Multiple Instance ticked, it’s under the options menu.
  • Stephen Morriss
    29 March 2007 at 14:37
    I’ve got version 7 and that can have multiple copies open, I seem to remember that you could install a plotter que that takes over when you send to the cutter, that should free up the current window.
  • Stephen Morriss
    29 March 2007 at 14:38
    I was just about too edit my post to say that 🙂 Beat me too it Brian
  • Brian Hays
    29 March 2007 at 17:39
    quote Stephen Morriss:
    When you install Signlab I think it always defaults to being turned off, not sure why. If you speak to Bernie @ Cadlink he will tell you to leave it that way. Not quite sure why though? but he definitely doesn’t like it!
  • Gavin MacMillan
    29 March 2007 at 19:26
    Cheers!!
    I’ll try that tomorrow, can’t believe it’s been annoying us for so long and it’s 1 tick box!!
    Gavin
  • Gavin MacMillan
    30 March 2007 at 06:58
    Thanks! That did the trick!
