can i fit Etch Glass quickly when applying with water?
Hi All,
I remember a couple of years back, reading a post whereby Robert Lambie and an old forum member debated the pros and cons of fitting etched vinyl.
The basics of the debate, form the old member`s point of view, were that if the etch glass vinyl was applied wet, the best way to produce zero bubbles was to apply (wet), squeegee and leave overnight before removing the backing. This allows the vinyl to dry out etc. I must say this is a practice i have used with success.
Robert`s argument, and a very valid argument, was that how could you afford to return the next day to a job which, in essence, should have been finished the previous day. Obviously technique plays a huge part in this but i can`t remember if Robert applied dry, allowing him to complete the job in one visit or if he applied wet using some special formulated super solution that allowed the vinyl to stick and stay in place while the application paper is ripped off.
How do you guys go about this?. The reason i`m asking is that we have to cover windows at a newly built hotel in Fife and i`m loathed to eat into a second day`s work time simply to remove application tape. Especially as it`s an hours drive there and an hour back.
I`d like to be able to apply wet, squegee and remove all in one go but i have never been able to do this without distrubing the etch on the glass and making an arse of it.
Ladies and gentlemen, i need your advice.
Tia.
