Home Forums Sign Making Discussions General Sign Topics Can I cover a cistern outlet?
  • Can I cover a cistern outlet?
    Posted by John Singh on 19 November 2009 at 19:29
    To put a sign central above a doorway would mean it would have to go over a cistern outlet which protrudes no more than about half inch (12mm) from the wall
    The customer has asked for this to be done although I’ve suggested keeping it away from the outlet
    Just wondered if there were ‘no’ no’s in putting it over the outlet if I left enough room behind the sign?
    John Callaghan replied 16 years, 1 month ago 5 Members · 5 Replies
  • Nigel Hindley
    19 November 2009 at 19:33
    What do you mean by cistern John? is it just an overflow? shouldn’t be a problem as long as you leave a few mm they are after all only in use if there is a problem?
    Nigel
  • Mike Grant
    19 November 2009 at 20:27
    Cut a hole in the sign. 🙄
  • John Singh
    19 November 2009 at 22:06
    Its just an overflow pipe from the toilet cistern
    19 November 2009 at 23:12
    If the pipe only protrudes 12mm (ish) from the brickwork then it has already been cut or broken at some time John. Long as it can still allow water out if the cistern overflows then there shouldn’t be to much of a problem. I would imagine if they ever needed to get at the outside of the pipe then the sign could be removed.
  • John Callaghan
    21 November 2009 at 10:52
    A sheet of plywood would bring the sign flush with the outlet and make it a little bit less noticeable.
