Can contravision be applied internally to a window?
Posted by Nick Tunstill on January 31, 2012 at 5:17 pm
The question says it all really. I have a customer who wants a shop window with contravision applied to the inside. I have applied to vehicle windows but the adhesive is obviously on the reverse.
You can print reverse onto clear, back with white, then back with black, then cut out small horizontal strips around 3mm leaving 5mm print (have to test the gap ratio) and apply to the inside. That should work fine
Please note:
