Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters can anyone tell me with graphtec 3000-60 cutting problem?
  • can anyone tell me with graphtec 3000-60 cutting problem?
    Posted by John Wilson on 10 February 2006 at 12:11
    When cutting circles or rounded text my cutter doesn’t cut the whole circle, I haven’t really noticed this before until I started cutting really small logo’s. It misses out a very small section and doesn’t complete the join meaning that I have to cut it with a scalpel when weeding.
    Anyone know how I can fix this?
    John Wilson replied 19 years, 11 months ago 3 Members · 3 Replies
  • Nigel Pugh
    10 February 2006 at 12:20
    That would suggest that your offset is set a little too low on your machine.
    Too low and it will undercut, too high and it will overcut.
  • jeffus – Graphtec
    10 February 2006 at 15:57
    Hi John,
    check your off set like Nigel has suggested, if you are using graphtec blade and holder with the blue top make sure, the settings for the off set is CB09.x 0 , if the blade has started to wear adjust the offset + – until your circles improve. also check your cutting strip is in good condition, and unscrew the blue top from time to time give the bearings a wipe and add a tiny dab of grease, helps the life of blade and holder. 🙂
    Jeff
  • John Wilson
    10 February 2006 at 21:10
    I’ll give it another go in the morning but I think I might need a new blade aswell so better order one just incase
