Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters can anyone tell me if vista works with pcut630 please?
  • can anyone tell me if vista works with pcut630 please?
    Posted by anthony lee on 20 January 2008 at 22:52
    hey all, after searching this forum.. i found many useful posts and threads on how to install the USB pcut 630.
    I have a 32bit vista pc…
    i just bought a creation pcut 630 – after a few weeks of play with my graftech cc200-20 i wanted to upgrade to a slightly bigger cutter..
    ive spent 2 full days trying to install it without success, ive just signblazer elements and am awaiting the registration code.
    Ive followed the thread on how to install the drivers, in which i have set up the settings recommended, ive also switched so i am using COM 1.
    When i switch the cutter on i just see blocks of black dots on the lcd display, even when i have installed the drivers correctly, which also display on the pc that they are fully installed.. when i press online the cutter still does not change from the black dots..
    could this be because of vista, as most ppl i see on here are using there pcut with xp…
    any1 with any tips/advice on how to get this tank of a thing working :lol1:
    thanks guys
    PS guys im a complete newbie…so bare with me 🙂 and i plan to use my cutter for mainly garment vinyl.
    Alistair Richards replied 17 years, 4 months ago 10 Members · 25 Replies
  • 25 Replies
  • Kevin Flowers
    20 January 2008 at 23:00
    don’t have knowledge of your cutter but i would say seeing just black dots is a cutter fault. Most cutters will display a menu, online offline wording etc when switched on. Does the cutter initialize when switched on as in measure the vinyl loaded?
    kev
  • anthony lee
    20 January 2008 at 23:05
    hi no it stays with black dots,
    i spoke to the previous owner just now and she said that when i press online, the menus should come up as long as it is connected to the pc/installed.. shes running off xp..
    any1 with this cutter and vista?
    thanks
  • John Davis IOM
    21 January 2008 at 09:14
    With the Pcut diconnected from the pc what happens when you switch it on?
    It should still run through its checks, I think it says pcut 630, then software version and then it should come up "on line".
    If it does not it would suggest the plotter is at fault.
    John.
  • anthony lee
    21 January 2008 at 09:49
    hi without the pcut connected it stays with black dots, o dear.. looks like im gonna have to get a refund.. such a hassle as delivery was a bomb!
    any1 else confirm this before i send it back?
    thanks
    ant
  • John Davis IOM
    21 January 2008 at 09:59
    The only other thing I can think of to to check is that the head of the cutter is not up against one of the red stops at each end of the carriage.
  • anthony lee
    21 January 2008 at 10:13
    this is how the head looks[/list]
  • anthony lee
    21 January 2008 at 10:15
    ahhhhhhhhhhhh
    i just moved the head out and now it boots up!!!
    (hot)
    thanks john life saver! im gonna try it later and see how i get on!!!
    thanks a bunch guys!!
  • John Davis IOM
    21 January 2008 at 10:17
    Try moving the head to the left whilst the machine is turned off. Then see what happens when you switch it on….
    Didn’t see your other post… Glad to be able to help!!! :lol1:
  • anthony lee
    23 January 2008 at 13:46
    hi guys, ok ive made a little progress, ive done the test cut.. and it cut fine.. and ive installed it as when i plu it in – on device manager it comes up as usb serial convertor – com2
    now when i have something to be cut in sbe, setup the cutter as shown below
    then i press cut tile
    then the cut master pops up with the job however nothing happens???
    [img=http://img218.imageshack.us/img218/746/sbe4pd6.th.jpg]
    any one any ideas?
    thanks guys
  • Angelique Muller
    23 January 2008 at 18:55
    I would suggest you check the Signblazer forum (don’t know exact address, but you will find it easily trough Google). It explains the set-up well (there is something about the port you have to select in both the initial set-up and when you are cutting).
    I remember I had some initial problems… but they are very help full there in sorting your problem…..
  • anthony lee
    2 February 2008 at 14:14
    hi guys, i went over to sbe forum, did what they asked, played with config settings.. still no luck….. hmmm looks like im gonna have to sell it 🙁
  • Angelique Muller
    2 February 2008 at 14:45
    Would you not contact your supplier first and see if they can sort out the problem?
  • anthony lee
    2 February 2008 at 14:52
    i bought it 2nd hand from ebay.. i think they bought it from signwizard, i shall drop them an email however i reckon they will be reluctant to help a 2nd buyer.
    ant
  • anthony lee
    7 February 2008 at 18:07
    hi is any1 able to help me, located in leicester – i am willing to pay money fr some to help me set this up on my vista pc.
    regards
    7 February 2008 at 19:19
    Have you tried running it from a different PC, it may well be that there are no drivers available for it under Vista so you would need to run from XP like the previous owner.
  • anthony lee
    7 February 2008 at 19:23
    hi no i havent, i dont have access to an xp machine, however ive read a few people running the pcut 630 on the vista with success, so i must be doing something wrong?
    7 February 2008 at 19:29
    Have you tried visiting the Creation website and downloading the latest drivers for the plotter?
  • anthony lee
    7 February 2008 at 19:34
    ive just been on http://pcut-cn.com/edownload/download.php
    i cant really see any vista drivers, ive also tried signwizards usb driver without success
  • Steve Sandy
    7 February 2008 at 20:05
    Hi Anthony,
    How long is your usb lead, I had the same problems a while ago and I had mine on the extension lead, Karl on here suggested using the smaller lead and it started working fine and have had no problems since.
  • anthony lee
    8 February 2008 at 15:44
    hey steve thanks for the tip il try find one and test it out
    thanks
  • anthony lee
    19 February 2008 at 18:56
    AOOOOOOOOOOOOOWWWW(hot) (:) 😛 :lol1: 😎 😀 🙂 😮
    IVE GOT IT WORKING!!!!!!!!!!!!!!!!!!
    THANKS GUYS YOUVE BEEN GREAT
    AAAAAOOOOOOOOOOOWWWWWWWWWWWWWW
    NOT SURE WHAT IT WAS, BUT IT JUST CUT !!!!!
    BACK IN BUSINESSSS!!!!!!!!!!!!!11
    OK TIME TO GET RID OF MY STUDENT OVERDRAUGHT!!!!!!!!!!!!!!! (hot)
  • James40
    3 August 2008 at 19:20
    Hi Anthony, . I’ve had mine since March and I’ve had no end of problems have you solved all yours?
    mod-edit
  • Tracey Vaughan
    12 August 2008 at 19:28
    hi i have had exactly the same problem, bought a cutter the same as you one off ebay, with same prob when lucky enough to get it to start, i cant get to cut.
    i now this sounds daft but i am having to turn off and leave for a while ,then it starts lesson to us all don’t buy of ebay or someone could make a fortune making a installation cd for us on basics of cutters and how to set up idea there somewhere !!!
    if i can get mine going will gladly pass on info.
  • John Thomson
    12 August 2008 at 19:38
    Tracy,
    I am sure there is a thread on here where people have posted the setup settings?
  • Alistair Richards
    13 August 2008 at 16:02
    In Sign Blazer, try changing the cutter settings so that it cut direct instead of through cutting master.
