Home Forums Sign Making Discussions Neon, LED, Lighting Can anyone recommend a clear acrylic glue?
  • Can anyone recommend a clear acrylic glue?
    Posted by David McDonald on 12 December 2005 at 03:00
    Hi All
    Need to glue a strip of clear acrylic onto the back of two butt jointed/routed Opal 050 panels for a light box, ie to create a tongue and groove joint.
    Also I need to go to bed as its 3 in the morning.
    Good Night
    David McDonald replied 19 years, 11 months ago 3 Members · 4 Replies
    12 December 2005 at 03:18
    amari plastics do tensol. i have a case of the stuff which has taken me god knows how long to go through…. still got a fair bit left.
    there are also various adhesives on offer from grafityp, i believe they do a range of fusion adhesives. which again will do the job perfectly for you… i recently had some sample bottles of the stuff and it worked very well…
    as you say its after 3:15am here so ill have to hit the sack soon. 😮
  • Glenn Sharp
    12 December 2005 at 09:41
    As Rob has said,
    Tensol 70 is a two part mixture that will go off in about an hour
    Fusion is a liquid you syringe onto whatever you are sticking (welding) but only takes seconds to go off – which also means less chance of slippage between the two acrylic components
  • Glenn Sharp
    14 December 2005 at 13:26
    No problem at all – glad I could help
  • David McDonald
    14 December 2005 at 13:38
    Went for the Fusion 500 as I just happened to have a Grafityp catalogue to hand.
    Thanks All
