Home Forums Sign Making Discussions Neon, LED, Lighting can anyone identify these plastic fixings to join two panel
  • can anyone identify these plastic fixings to join two panel
    Posted by Aurbab Zafar on 14 April 2013 at 16:12
    Hi guys,
    I’m doin a job where we’re replacing the panels in an existing panatrim frame. The old panels were 3mm foamex, which I will replace with 3mm di-bond.
    However, usually when putting in more than one panel into a frame, I join the two di-bond panels by creating a ‘slot and groove’ system using di-bond cut-offs and glue, to make sure both panels stay aligned perfectly at the join(s) and dont create a gap between each other.
    On this job, I took of the existing foamex panel (only one side remained), and I found these VERY interesting plastic fixings which look like a male/female system that does exactly the same thing! I only have a pic of the left-side panels bracket, I’m thinking the right-side had a similar bracket which fitted into it to create a snug join between the panels. Does anyone know what these are and their technichal name? They seem to be perfect for the job and I’ve never seen them before.
    Thanks!
    Aurbab Zafar replied 12 years, 8 months ago 7 Members · 10 Replies
  • 10 Replies
    14 April 2013 at 16:14
    panel locks, you could by them from SMP but they were bought out by Ashby trade supplies. give ashby a call as they may now do them as a result.
  • Aurbab Zafar
    14 April 2013 at 16:18
    thanks robert! ‘panel locks’ isn’t a keyword I asked Mr. Google, so it make sense. I’m thinking these wouldn’t be suitable for backlit panels (acrylic) as their shadows would show up through the acrylic? perfect for unlit panatrim signs. thanks again!
  • Aurbab Zafar
    14 April 2013 at 16:29
    just trawled through ashby’s website and can’t find them? any other suppl;iers? thanks.
  • NeilRoss
    14 April 2013 at 16:48
    Try searching for panalock.
  • Aurbab Zafar
    14 April 2013 at 16:59
    thanks neil but ‘panalock’ throws up nothing too, hmmm these little buggers are elusive lol
    14 April 2013 at 18:30
    Google is your friend if you know what to search for lol. Try acrylic panel locks
    http://www.hellotrade.com/sign-makers-p … duct1.html
    Use to buy them from SMP same as Robert, don’t know who if anyone sells them now.
  • Gary Birch
    14 April 2013 at 19:09
    Pretty sure ashby still sell them. Smp used to do 2 types, I’d give them a call tomorrow
  • Martin Gray
    14 April 2013 at 22:28
    I phoned them a few days ago about them. Was told he investigate and phone back. Ive had no call as of yet!!
    Martin
  • Adrian Hewson
    14 April 2013 at 23:03
    Various different manus but have used these guys before but honestly normally make them ourselves
    http://www.goodingalum.com/p10/c64/Alum … oard-Trims
  • Aurbab Zafar
    15 April 2013 at 17:24
    Guys, just rang ashby and they confirm they have two types, one type is a ‘lift and drop’ type where the second board has to be lifted slightly above the first and then dropped into the grooves on the female side, the other is a ‘click and lock’ type where you can push them together and they simply ‘click’ into place. They’re 53p each and I’ve ordered samples today. Thanks very much for all your replies.
