Home Forums Software Discussions Corel Software can anyone help with quick question about corel draw?
  • can anyone help with quick question about corel draw?
    Posted by Adam McGuire on 21 November 2006 at 11:00
    Hi all,
    I have a little problem with CorelDraw. It’s the same in versions 9, 10 and 11 to my knowledge. I want to position some text dead centre with an eps logo. I can set coordinated for the logos no problem, but I cannot work out how to set the coordinates for the text box! Call me stupid, but I can’t find it anywhere! I’m using Corel 10 in work as that’s what is on the network here. I usually use 11 or 9. I can’t use flexi (in which I can easily locate anything) as I don’t have my laptop with me.
    Any help most appreciated!
    Adam
    Alan Drury replied 19 years, 1 month ago 7 Members · 15 Replies
  • 15 Replies
  • Alison Falzon
    21 November 2006 at 11:28
    If the text is done as artistic text, rather than paragraph text I would just select the eps logo, then place a ruler guide on the central cross, then move the text and line it up to the guide (if that makes sense!)
  • Adam McGuire
    21 November 2006 at 13:34
    Thanks for the reply. What you’re saying does make sense, but it’s paragraph text not artistic. I might try again. It was only for a mock up, but I wanted it all to be centred to the page.
    Adam
  • Alison Falzon
    21 November 2006 at 13:44
    Or you can click on "layout" at the the top, then "align and distrubute", there are different options you can choose that might help
  • Nick Minall
    21 November 2006 at 13:47
    If you need it centre of the page just select it and press P on the keyboard
  • Stevo Chartrand
    21 November 2006 at 13:55
    Group your logo. Select your text, hold shift, select the logo then hit "e" and "c". Done!
    (corel 11)
    Stevo
  • Adam McGuire
    21 November 2006 at 14:03
    That flippin brilliant that is! Then I can simply adjust the height of each part of the logo! Cool! 🙂
    Thanks again,
    Adam
  • Alison Falzon
    21 November 2006 at 14:18
    I never realised all those keyboard shortcuts existed! very handy!
    21 November 2006 at 17:34
    There are loads of shortcuts in Draw, try this – hold the shift key down and drag corner node, object will then resize in proporting from the centre.
    Alan D
  • Stevo Chartrand
    22 November 2006 at 13:28
    Here’s a few more shortcut keys.
    I use these as much as possible. It really does speed things up and once you really get to know them it’ll become second nature.
    Stevo 😀
    Ctrl+A – Select All
    Ctrl+Z – Undo- I believe you can have up to 99 undos!!
    Ctrl+Shift+A – Re-do
    Ctrl+X – Cut
    Ctrl+C – Copy
    Ctrl+V – Paste
    Ctrl+O – Open File
    Ctrl+P – Print
    Ctrl+S – Save
    Ctrl+W – Window Refresh
    Duplicating Objects:
    Ctrl+D This way you have to set your X & Y axis parameters.
    Ctrl+C then Ctrl+V Duplicates object right on top of original to the front.
    "+" sign on your number pad. Duplicates object right on top if original but will keep it on the same layer.
    Select object- Drag it- and right click with the left click button at the same time.
    Align and Distribute
    Align Left- L
    Align Right – R
    Align Top – T
    Align Bottom – B
    Aligh Horizontal – E
    Align Vertically- C
    Center of Page – P
    Order
    To Front Shift+PageUp
    To Back Shift+PageDown
    Forward One Ctrl+PageUp
    Back One Ctrl+PageDown
    Grouping
    Ctrl+G Group
    Ctrl+U Ungroup
    Ctrl+U+U Ungroup all
    Combine Ctrl+L
    Break Apart Ctrl+K
    Effects:
    Ctrl+F9 Contour
    Ctrl+F7 Envelope
    Holding Shift when resizing will size it uniformly.
    Holding Ctrl when moving and object will keep it on axis
    Double click on ruler. Brings up nudge options menu
    Double click on Box Tool will make box the size of your page.
    Z – Zoom
  • Alison Falzon
    22 November 2006 at 13:37
    That’s great! I use some of the shortcuts already – for copying / duplicating etc, but I didn’t realise there were all those layout ones in Corel.
    You’ll be suprised at how much time it saves!
    Thank you for that, it’ll come in handy!
  • Stevo Chartrand
    22 November 2006 at 14:03
    You’re welcome!
    I’m sure there are a few more that I don’t know. So if anybody wants to add to this, I’m all ears!
    Stevo
  • Adam McGuire
    22 November 2006 at 14:05
    Flippin eck! That’s a list….I suppose you never think about how many you know until you start to write them out!
    Adam
  • Andy Gorman
    22 November 2006 at 14:06
    Ctrl Q – Convert to curves
    22 November 2006 at 17:43
    Ctrl Alt del – Sh1t 😕
    22 November 2006 at 17:53
    Too many to mention and VBA can be assigned short cuts too.
    Alan D
