Home Forums Software Discussions Signlab Software can anyone help with omega om-80 signlab settings please?
  • can anyone help with omega om-80 signlab settings please?
    Posted by harl on 7 October 2006 at 15:11
    hi to all again i am not having much luck at connecting this machine to win xp it came with an usb adaptor, a lpt cable and a com port cable but i do not know how to make win xp reconize any of these i have signlab 7.1 and i dont even know if the settings for this plotter in this program are correct.
    thankyou for anyone who views.
    david
    harl replied 19 years, 2 months ago 2 Members · 2 Replies
  • Rod Young
    10 October 2006 at 14:59
    quote harl:
    Hi David,
    • First off, do you have the Operator Manual with your machine? What do they recommend in there about hooking up your machine, or is there a web site that has the info.
    • Second, can you restate the manufacturer and model number of the machine.
    • In SignLab, you want to go File menu >> Install Cutting Devices. This will provide you with list of available machines. Just tick your machine and its device driver will be installed.
    • Once the driver has been installed, go Cut menu >> Plotting Defaults.
      You want to click the Setup button, then Port tab, and then indicate the Port Location to which the machine is connected to your computer.
    • For tutorials about using SignLab, I would recommend the CADlink InfoSource site that is located here:
    http://www.cadlink.com/infoSource/nfo_tutMain.php
    If after all this you still aren’t getting joy, then I would recommend contacting CADlink Tech Support.
    Cheers,
    Rod at CADlink
  • harl
    10 October 2006 at 15:52
    thankyou for your reply i have now sorted it thanks to you.
    thanks again
    harl
