Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters can anyone help with measurments on graphtec ce1000?
  • can anyone help with measurments on graphtec ce1000?
    Posted by Jonathan McGovern on 12 March 2007 at 18:02
    Hi people
    i have a graphtec ce 1000 attached to my signlab and flexisign but on each programme i have to manuelly type in the measurent the plotter measures when i set the vinyl up…… my uncles easysign gets that inf from the plotter its self!
    its not fair! 👿
    Jonathan McGovern replied 18 years, 10 months ago 3 Members · 6 Replies
    12 March 2007 at 18:19
    you are probably driving it from the parallel port.
    the plotter can only talk to the computer by serial or usb.
    or something i dont know in sl
  • Jonathan McGovern
    12 March 2007 at 18:32
    hi thanks for the reply, i am using a usb cable, i wasnt sure if i had to tell the software or plotter to get the measurement.
    12 March 2007 at 18:42
    quote :
    in that case a sl or flexy person will be along soon
  • Frank Droog
    12 March 2007 at 21:44
    I dont believe a CE1000 has a USB port.
    Are you using a USB to serial cable to connect your serial plotter to a USB port on your computer?
    This should work fine.
    I myself use a USB to serial cable and have full bidirectional communication. I Use it constantly with our FC7000,FC5000 and CE5000
    Page size works and plotter ID work.
    Are you using a HPGL driver or a GPGL driver.
    May not work with the GPGL.
    What happens when you press Get Page Size of Plotter ID in Signlab.
    Frank at Cadlink.
  • Frank Droog
    13 March 2007 at 20:54
    Found we also have a CE 1000.
    It doesnt have a USB port.
    Connected it to a computer via a USB to serial cable.
    Both Plotter ID and Get Size seem to work fine.
    What exactly happens when you try?
    Do you get an error message?
    Crash?
    Error on the plotter?
    Incorrect return value?
    I cant see a problem here at our end.
    Frank at Cadlink.
  • Jonathan McGovern
    13 March 2007 at 21:03
    hi Frank,
    i use a usb – serail adaptor lead, ill check the error message in the morning and let you know…..
    Been hectic today! so glad it sounds like i might get this sorted!!!!! 😀
    thanks frank
