Home Forums Software Discussions Flexi Sign Software can anyone help with cutting problem & Flexisign 7.5pro
  • can anyone help with cutting problem & Flexisign 7.5pro
    Posted by John Bell on 7 August 2007 at 06:58
    🙁 I have just got a roland cx24 and am using flexisign 7.5pro the problem is everything is 90 Degrees out for cutting for example what you see on the screen in portrait view cuts landscape or vice versa I had the same problem with my pcut but I was able to get a CSM file and drop it into the drivers directory which cured the problem apart from changing the orientation in flexi can any one help
    John Bell replied 18 years, 4 months ago 4 Members · 4 Replies
  • David McDonald
    7 August 2007 at 08:01
    I’ve not owned a Roland brand plotter but on all the other plotters I’ve owned and currently own there is an ‘axis orientation’ (or similar name) setting via the plotter menu. Maybe that is set incorrectly and could be worth checking?
    Macky
  • Gavin MacMillan
    7 August 2007 at 08:05
    It should be in plotter options in the software, it is on signlab anyway.
    G
  • Neil Davey
    7 August 2007 at 08:07
    Try clearing preferences in the Flexi application menu. This is always a good place to start when there are little glitches.
    Neil
  • John Bell
    7 August 2007 at 15:21
    :lol1: Thank you all very much the setting was on the plotter everything is fine now
    yours john
