Home Forums Software Discussions Corel Software can anyone help with corel X3 problem please?
  • can anyone help with corel X3 problem please?
    Posted by Nick Williamson on 30 January 2008 at 14:22
    spent hours drawing out a piccy
    came back today tried to open it system keeps going back to desk top.
    have tried importing file to a new page system hangs up then warning system unstable comes up. just under 3meg file have also had problems importing other corel files into opened documents any ideas would be appreciated cheers Nick
    mod-edit
    Please use more discriptive topic titles.
    This topic has now been edited.
    Alan Drury replied 17 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
    30 January 2008 at 15:15
    Ensure you have the latest SPs installed should show as 13.0.0.739 in the ‘about Corel’ tab.
    You can try importing the cdr instead of opening, also drag and drop from Explorer (this worked from some problem ai files). Failing that I would save your desktop if customised, close Draw, relaunch with F8 pressed, accept the factory default workspace and then try again.
    If you can get into Draw and can run the convert macro you can try converting the cdr to cmx and then importing that. That will strip any styles from the cdr.
    Alan D
  • Nick Williamson
    30 January 2008 at 15:46
    Thanks alan
    have tried re start corel with f8 pressed and guess whot file opened up ok and can modify it.
    just checked version 13.0.0.667 will try to up date thanks again
    cheers Nick
    30 January 2008 at 16:48
    I think 667 was the first SP, the second one is readily available but is about 40meg from memory.
    Glad you’re sorted, it’s worth remembering the F8 thing it does cure alot of unexplained issues.
    Alan D
  • Nick Williamson
    31 January 2008 at 16:53
    Thanks have down loaded update so lets see what happens now.
    After the ease of sign lab outline tools corel is so complicated at times
    thanks again have printed off a stickr with f8 in case of emergency etc
    cheers thanks again.
    31 January 2008 at 18:32
    Don’t confuse outline with contour in Corel, must dash now but post your problem and I’ll try to sort tomorrow sometime.
    Alan D
  • Nick Williamson
    1 February 2008 at 12:34
    Thanks again been using the outline tool then converting outline to object etc takes an age. Use to have corel 8 then version 11 but am so used to using signlab corel got left behind but now with the arrival of our versacamm we have found corel or photoshop have to be used dont want to start a discussion which is best each does certain things better.
    Any hints on fades for backgrounds or photos welcomed actually anything really
    cheers Nick
    1 February 2008 at 13:03
    Use the contour tool, it is now curves not straight lines, group objects and then apply contour to do all of them, I have a script somewhere which then enables you to round corner but obviously you could ‘break contour group apart’ and the use Corel’s fillet option. Fades are easy in Corel which bit are you getting stuck on?
    Alan D
