Home Forums Software Discussions Corel Software can anyone help please with letter outline Corel Draw 12?
  • can anyone help please with letter outline Corel Draw 12?
    Posted by Chris Theakstone on 8 December 2006 at 19:47
    Hi, Having just changed plotter and now cutting direct from Corel i am struggling to reproduce the same letter outline as I did in Winpc sign.
    i can creat the outline around the letter (a 4mm outline 4mm from the letter) using the contour tool but want the corners "clipped" or even rounded which I can’t seem to be able to achieve.
    As always very gtateful for any hints and tips.
    Chris
    Alan Drury replied 18 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • LeeMorris
    8 December 2006 at 20:14
    If you select your text and press f12 it brings up the box with all the options for outlinging , in there you can change everything , colour , size,corners etc.
    Lee
  • Chris Theakstone
    8 December 2006 at 20:48
    Thanks lee, but it dosen’t have any effect. What I am doing is using the contour tool, creating two lines around the letter 4mm away and 4 mm apart to give a cut letter with a 4mm outline around it it is this 4 mm outline that i would like to change the corners on.
    Cheers Chris
  • LeeMorris
    8 December 2006 at 21:01
    Hi Mate
    I’m not up on that really , there is a guy on here called Andy Gorman who seems to know a bit about corel.
    Lee
  • Nick Minall
    8 December 2006 at 21:19
    you could try this plug-in.
  • Andy Gorman
    8 December 2006 at 21:30
    You’ll need Coreldraw X3 to get a radiusing tool. It’s called ‘Fillet’ in X3. I used to use ver 12 and I am sure it doesn’t have this feature. The only other way you could do it is to use the pen tool with a round corner and then "convert outline to object". You will have to delete some unwanted bits though.
  • Chris Theakstone
    8 December 2006 at 21:45
    Thanks Andy and everyone, I got around it by drawing it all up in Winpc sign then exporting it as an AI into corel then cutting it phew ! a bit long winded but got there.
    Cheers chris
    9 December 2006 at 10:47
    Fillet tool works well in X3, I also have a macro here that does rounding etc to contours.
    Alan D
