Home Forums Printing Discussions Uniform Printers can anyone help please with contour cut with cadet?
  • can anyone help please with contour cut with cadet?
    Posted by eddie cotter on 17 May 2004 at 22:29
    i new ide be looking for help soon enough! i dont know if i knocked a setting out but if i print say five labels across in the one line & want to contour cut after printing, it goes & cuts five smaller boxes over the printed labels, i design in signlab, export it to corel9 as an ai
    then export it as eps to troop, with a contour cut line any help would be great as i have a load of labels to get out tomorrow 😮 eddie
    eddie cotter replied 21 years, 7 months ago 3 Members · 5 Replies
    17 May 2004 at 22:41
    do you use this series of actions to normal contour cut eddie?
    what i mean and if im reading right is, you normaly would do this and it cuts fine and this time its cutting over the top of your prints?
  • eddie cotter
    17 May 2004 at 22:53
    yeah rob, did 50 8″x4″ oval stickers today with contour cut, first class job!!
    then this evening my first trade job came in, 100 5″x3″ simple labels plain text white back must have by tomorrow, so as i am only feeling my way & afraid of loads of media in the bin! i did a sample print & cut of five &
    when the machine went to contour cut i did a smaller cut over all five labels!!! each cut was a lot smaller & well of line, its like its like the plotter isnt communicating with the printer! bloody typical isnt it, just when i need to deliver the goods things go pear shape, (:) eddie
    17 May 2004 at 22:59
    its always the same with new kit mate. i know this isnt gonna help but im sure its something very silly being overlooked.
    are you saying it contour cuts but the does another over the top also or just that the contour cut is not aligning properly?
    my problem here is i have not used troop just yet, & i dont use corel 😕 fat lot of good ill be here eh..
    have you maybe changed an offset or some kind of setting. have you tried closing everything down then starting up again (if you havent touched anything)
    try creating the file again.. not from scratch just re-apply the contour cut again and go thru your series of actions and try again with one or two..
    it may well be something in the way you set up the contour cut and didnt realise it.
  • Rodney Gold
    18 May 2004 at 03:59
    Try this.
    1) Turn off the machine and reboot it (the plag switch)
    2) Import only the TEXT into corel and re-design the contour cut line in Corel
    3) Export as a postcipt 3 file (under advanced tab when exporting)
    I
    f that doesnt work , heres a likely workaround , split the plot into 2 , the printing section and the cutting section. When exporting , select PAGE and not objects (then the print and cut will be in register) and tell the rip to rewind the print to the origin (start point) after printing. Print and then do the same for the cut file.
    Im not at all familiar with the Trooper RIP , but this is most likely a translation problem between signlab/corel/rip.
  • eddie cotter
    19 May 2004 at 21:01
    thanks robert & rodney, i must have messed with the cut settings on the troop rip, rang b&P & graham sorted it over the phone, now thats what you call after sales service, so guess who will be getting my next order for equipment 😉
