Home Forums Software Discussions Signlab Software can anyone help please im unable to import files?
  • can anyone help please im unable to import files?
    Posted by BenRead on 7 July 2008 at 08:08
    Hi guys, i have signlab 6.1 and am having some difficulty importing files into the software, when i try to import the usual L shaped cursor appears i click as normal and then nothing appears. This is not the only problem, i have tried to drag items in from illustrator as i would have previously done and i am unable to group them. With this problem i also tried to print the image and it says that when i can clearly see the image on screen no item to print!! please help, this is stopping me from doing some business. if no solutions can anyone suggest who to call??
    Your responses would be extremely appreciated.
    Ben
    Gavin MacMillan replied 17 years, 4 months ago 2 Members · 2 Replies
  • Brian Hays
    7 July 2008 at 08:39
    The people that sold you the Signlab may be a good start? (-)
  • Gavin MacMillan
    8 July 2008 at 05:36
    Not being able to print sounds like the items are on different layers. Try getting rid of layers and then printing.
    Not sure about drag and drop from illustrator but maybe there are locked objects that need seeing too?
    Are you sure the files you are trying to import are supported and also not just rubbish files. Did you try importing them into other software? Older versions of signlab never were great at importing but we normally fine for ai and eps.
    These are all wild stabs in the dark, if you can explain what things you have tried it might narrow it down.
    G
