Home Forums Software Discussions Signlab Software can anyone help me with SignLab 5.0 USB port option?
  • can anyone help me with SignLab 5.0 USB port option?
    Posted by wildchildc1 on 14 June 2008 at 02:48
    I have SignLab 5.0 ver 12 and I just purchased a Graphtec CE3000-60 plotter and it is setup to run off the usb port.. My SignLab 5.0 does not have the USB ports as a option, only the Com 1-4. LT1-2 Windows driver and File options.. Is there anyway around this to use it with a USB cable or do I need to set up the plotter to use the Com-1 or LT-1 ports with the seriall or parallell cables? I tried to find a update that added the USB ports as a plotter set up option but I havent found one. If anyone has seen this update or has a easy option please let me know? Thank you,
    Graeme Harrold replied 17 years, 6 months ago 2 Members · 2 Replies
  • Brian Hays
    14 June 2008 at 07:34
    Signlab 5.0 doesn’t have USB support. It’s too old. Don’t think USB arrived until version 6.0, maybe even 6.1. So you will have to stick with running it Serial. 😥
  • Graeme Harrold
    14 June 2008 at 10:05
    If its the same as EngraveLab then its a big no to USB. Its kind of holding me back as it aint easy finding a new computer that has serial/parallel ports (or the ability to easily add. The only option is to use USB port replicators. I need Serial for the machine and Parallel for the software dongle!
