Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters can anyone help me with fine detail cutting please?
  • can anyone help me with fine detail cutting please?
    Posted by John Cooper on 23 October 2007 at 11:58
    Hi guys
    We have a new Graphtec CE500 and we’re just starting to use it more
    Just a small problem when weeding fine detail cutting. It seems there are slight threads still attaching to some fine detail areas particularly where the cutting direction changes through an acute angle.
    The upshot of this is that when weeding we have to be careful not to weed some of the fine detail.
    Is there a setting on the Graphtec we could adjust?
    Hope you understand 🙂
    John Cooper replied 17 years ago 4 Members · 8 Replies
  • 8 Replies
  • jeffus – Graphtec
    23 October 2007 at 19:54
    a couple of things to try/ check,
    check your tool 🙂 is set to CB09 if you are using the blue top holder
    set the quality to 1
    make sure you don’t have too much blade
    unscrew the blue part of the blade holder and apply a small amount of grease or light oil to the bearings in the end (not wd40)
    keep the speed down to 20-30
    ensure the cutting strip is in good order should be if its new
    too much force can also effect the quality
    Jeff
  • John Cooper
    23 October 2007 at 19:59
    Thanks for the post Jeffus.
    I’m not going to do anymore tonight but will make sure the settings are correct in the morning.
    Cheers from Bridgend 🙂
  • Ian Bingham
    23 October 2007 at 20:39
    Why not WD40?
    23 October 2007 at 20:44
    Ian wd40 is not a good lubricant, and does more harm than good to small bearings, it washes out any viscous oil or grease, and dries up itself within a short space of time. leaving the bearing dry.
  • Ian Bingham
    23 October 2007 at 20:45
    Thanks Peter
    will stop using it! sewing machine oil OK?
    23 October 2007 at 21:13
    quote Ian Bingham:
    Thanks Peter
    ideal but hard to come by nowadays…
  • Ian Bingham
    23 October 2007 at 21:18
    got loads for our embroidery machines, will try it
    ian
  • John Cooper
    4 October 2008 at 16:47
    quote jeffus – Graphtec:
    Jeff
    Ours was set to 15U. Just changed it to 09 and it seemed to be fine 😳
