Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters can anyone help me set-up flexisign with Graphtec FC2100-60A
  • can anyone help me set-up flexisign with Graphtec FC2100-60A
    Posted by Joker on 18 October 2006 at 21:59
    Bought a used FC2100-60A but when I try to cut, it just rolls out the vinyl until the end.
    I am using Flexisign pro 7 on windows xp
    I saw it working alright when i bought it, it was cutting on corel draw 10 with windows 2000. I dont have corel draw
    its connected to the LPT1 centonics printer cable
    I hope you can hep me
    Joker
    Joker replied 19 years, 2 months ago 4 Members · 13 Replies
  • 13 Replies
  • Alan Wharton
    18 October 2006 at 22:17
    Is the cutter set to roll or sheet feed ? if its set to sheet it WILL run it to the end to measure the sheet ! 😉
  • Joker
    18 October 2006 at 23:24
    I think its on roll as when i press 1 or 2 it goes to online
    1 and 2 says roll
    3 says sheet
  • Joker
    21 October 2006 at 18:05
    has anyone got a manual for this cutter please
    so i can see if its on sheet instead of roll
    thanks
    21 October 2006 at 18:59
    When you load the media. you should see roll 1 roll 2 and sheet. next to the buttons, roll 1 will measure the width and find the edge of the material. roll 2 wil just measure the width, and sheet will measure the roll or however much material is in the machine.
  • Joker
    21 October 2006 at 19:12
    This is what i have been doing as i did to my gerber fastrak on flexisign
    I type in the text, then click on cut
    production manager comes up, select the driver and press send
    it then just rolls out the vinyl and even at the end of the roll it is still rolling on as if the roll was still there
    i have done this after pressing 1 and 2 and 3
    Do i need to press anything else for using flexisign
    thanks hope you can help
    21 October 2006 at 19:20
    I dont know flexi, but Have you selected the graphtec as your plotter, and set up the port and plotter at the same baud rate?
  • Joker
    21 October 2006 at 19:32
    yes select the graphtec driver plotter LPT1 port as am using centronics cable but cannot find baud rate
  • Brian Hays
    21 October 2006 at 19:33
    Only necessary to set the baud rate on serial ports Peter.
    Where did the Flexi come from? I assume you got it from a different place than the cutter if you saw it working with Corel?
    If it’s a legit copy give Graphtec a call. I am sure they will be able to sort the problem very easily. It’s obviously communicating otherwise it wouldn’t roll out some vinyl. Do you get any error messages on the cutter?
  • Joker
    21 October 2006 at 19:46
    hi brian
    yes i bought it some time back and used it with a gerber 650 fastrack, it worked great
    i dont have corel draw to see it work on this cutter
    if i dont press 1,2,3 on the plotter it starts cutting very very small numbers and letters ?
    no error messages
  • Brian Hays
    21 October 2006 at 19:49
    If you are getting small numbers you are probably sending the wrong language to the plotter. Graphtec’s can run in either HPGL or GPGL mode. When you turn on the machine it will display either HL or GL briefly. Change it to whicever setting it’s not on & it will probably solve the problem, fingers crossed.
  • Joker
    21 October 2006 at 20:01
    hi brian
    it comes up with GL
    How do i change it to HL
    I dont have a manual
    thanks
  • Brian Hays
    22 October 2006 at 08:57
    Sorry mate it’s a while since I have used one. You could also try looking in your software to see if it has a Graphtec HPGL driver. I know Signlab has Graphtec HPGL/GPGL drivers as well as named cutter drivers.
    Think you need to press pause, next to get in to the gutter menu’s. If you can’t manage it give Graphtec a call in the morning they will be able to tell you straight away..
  • Joker
    23 October 2006 at 14:10
    Thanks Brian and thanks Graphtec
    Yes it was the wrong mode, graphtec told me the procedure on how to change to hpgl
    Wow I thought i would have to go and buy Corel Draw !!! LOL !!!!
    Many thanks again
    Joker
