Home Forums Software Discussions Corel Software can anyone help me crop this picture?
  • can anyone help me crop this picture?
    Posted by Adrian Neill on 6 February 2009 at 09:24
    Good morning everyone !! It’s me asking for help again !!
    I’ve got this photo and I need to crop it. I know how to crop it as a square
    or rectangle, but I need to crop it as a circle. I’ve attached the picture
    and roughly where I need to crop it.
    I’m using Corel X3 if that makes any difference ??
    Cheers. 😀
    Hugh Potter replied 16 years, 11 months ago 7 Members · 13 Replies
  • 13 Replies
  • Gary Birch
    6 February 2009 at 09:27
    Adrian
    Can you not powerclip it instead??
    Draw your shape you want it to then select the photo then Effects, Powerclip then place inside container. You can then right click the container and edit or move it to the correct position the right click again to finish editing at this level.
    Gary
  • Warren Beard
    6 February 2009 at 09:28
    same process as discussed a few days ago in this thread
    http://www.uksignboards.com/viewtopic.p … ing#309282
    your circle is your path to clip in to.
    6 February 2009 at 11:02
    one way to do it, prob not the quickest but…
    select the shape tool,
    move the corner nodes so the edges of the photo fit the edges into the circle,
    convert edges to curves and bend to fit the circle, remove circle, job jobbed.
    ok, there’s possibly a proper way to do it, but that’s how i do it, only takes a minute or two, you can make the photo any shape you choose to (within the original confines of the photo edge).
    did a quick video (which i’ll leave up for a day or two) to show what i mean
    6 February 2009 at 11:09
    Power clip is the best way, you would then have the option to put an outline or shadow to the power clip shape. You can set Draw to either clip the bitmap where the power clip shape is positioned or auto centre the bitmap to the power clip shape.
    Alan D
    6 February 2009 at 11:24
    quote Alan Drury:
    Alan D
    where is powerclip Alan? i can’t seem to find it at a glance!
    Hugh
  • Gary Birch
    6 February 2009 at 11:27
    Hugh
    Under Effects mate
    Gary
  • Adrian Yeo
    6 February 2009 at 11:29
    Hugh
    Its just over half way down in the ‘effects’ tab.
    Don’t think there is a shortcut. 😀
  • Nick Williamson
    6 February 2009 at 11:45
    One way we have found that works well
    draw yer circle, position it over the bit you want
    select both bits
    go to arrange shaping intersect
    then you can select the bit you want plus the original picture is there untouched and the cut shape so you could intersect another image
    hope this helps
    cheers Nick (x3)
  • Adrian Neill
    6 February 2009 at 11:54
    wow … thanks for the respones !!
    I did actually manage it earlier just after i’d posted, but it was a long-winded
    way of getting to the end result !!
    Just tried the ‘powerclip’ way and it was soooo easy.
    Once again, many thanks for your help. 🙂
    6 February 2009 at 12:28
    ah, thanks guys!!
    power clips seems fine on most pics but on one or two it didn’t ‘contain’ all / the right area i wanted!!
  • Gary Birch
    6 February 2009 at 12:35
    Hugh
    right click and then edit…. move to where you want it then right click and finish editting
    Gary
    6 February 2009 at 12:39
    You can auto centre as well.
    Alan D
    6 February 2009 at 13:32
    thanks chaps, wonder if i’ll remember this the next time i need too! i generally only use cropped photo’s for t’s and mouse mats and i don’t do many of them either!
