Home Forums Software Discussions Corel Software can anyone advise with corel X4 positioning help please?
  • can anyone advise with corel X4 positioning help please?
    Posted by Colin Crow on 20 March 2008 at 10:51
    Since upgrading from X3 the graduations in the transformation/position docker have changed from 1mm to 0.1mm which means that a simple click on the up/down boxes for creating a 1mm gap between duplicates now requires 10 clicks.
    Does anybody know if this can be changed and if so where/how?
    Colin
    Alan Drury replied 17 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
    20 March 2008 at 11:00
    double click the ruler and a menu will drop down change nudge value.
  • Colin Crow
    20 March 2008 at 11:34
    This is fine for the nudge value but doesn’t affect the increment value in the Transformation/position docker. If I right click the position box in the docker and choose settings I can see the increment set at 0.1mm but I can’t change it here. When I check X3 this is set to 1mm so I am hoping there is a facility somewhere to change this.
    Colin
    20 March 2008 at 14:23
    sorry colin misunderstood but a bit stumped on your explanation, you can only alter Transform/Position value if you have something selected.
    or have i got the wrong end of the stick again
    20 March 2008 at 14:29
    oh see it now dont know as i always type a value in
  • Colin Crow
    20 March 2008 at 15:24
    Thanks Chris,
    When I lay out various sized items across a page, I found it convenient to click the item, click the right arrow (which sets the size) and then click once or twice on the up increment to set a 2mm space. Then clicking the duplicate button repeats across the area available. It meant no keyboard input necessary. Step and repeat works OK but has to be adjusted all the time for different sized objects. The .1mm increment is useless but also standard in signlab for some reason?
    Colin
    20 March 2008 at 17:45
    I see your point Colin, I’ve never noticed this before as I also type in a value. I’ll ask the question.
    Alan D
  • M Brown
    22 March 2008 at 18:45
    Hi men,
    Isn’t the setting right next to the nudge setting. It cant be that much different to X3 its the X Y value. Just type in the value you want the duplicate to go.
    Hope this helps
    From
    Mark
    23 March 2008 at 10:52
    Mark, yes you can but Colin is referring to a slightly different issue, from the position docker you can either type in a value or click arrows to increase/decrese value these increments used to be 1mm and now it is set to .1mm. This increment value when using arrows is not user definable.
    It has been mentioned on the beta forum and hopefully will filter through to the powers that be.
    Alan D
