Home Forums Sign Making Discussions Neon, LED, Lighting can an illuminated sign be built into stone pillars?
  • can an illuminated sign be built into stone pillars?
    Posted by Nicola McIntosh on 17 August 2005 at 09:39
    hi folks 😀
    a customer requires illuminated signs built into stone pillars, can it be done? any info would be much appreciated 😀
    Nik
    David Rowland replied 20 years, 4 months ago 10 Members · 18 Replies
  • 18 Replies
  • Andy Gorman
    17 August 2005 at 09:41
    I’m not sure I know what you mean, Nik. Do you mean a lightbox set into a recess in a pillar?
    17 August 2005 at 09:46
    yes something along those lines… 😀
  • Andy Gorman
    17 August 2005 at 09:51
    Well then, yes. Simple enough. I’ve done this before. You just need to find a lightbox that will enable you to insert the panel from the front, as the sides will presumably be hidden in the recess. I did this by using a section where the beading fitted into a slot so no screws were needed in the sides. Mind you, it was only a small sign. Then of course, you’ve got to get a wire in there………..
  • Vince Francis
    17 August 2005 at 13:19
    Can you post any kind of picture? There are several ways you can do this, but can depend on the design etc…..
    If you do, can you put as much info on it as poss
    Vince
    17 August 2005 at 20:08
    hi vince will post one tomorrow…the guys pillars are not even built yet 😮
    but i have a good idea to what he wants…’something enclosed with lights built in and plush’… those were the guys exact words 😀
    thanks big g for your suggestion also 😀
  • Adrian Hewson
    17 August 2005 at 20:25
    Ashby have a new machine that is primarily design to fabricate letters from aluminium and then the make up a snap fit fascia for the letters. This machine would work for your case, give them the dimensions of the recess and they then make a letter to fit, you take your power out the back along with fixings, put in your neon leds and then fit front fascia. They can do it in all sorts of colours and supply the best leds we have used
    Regards ADrian
    17 August 2005 at 20:32
    thanks for another lead adrian, but what puts me off that particular company is the attitude of the staff on the other end of the phone 🙄
    ed and me have phoned a few times for stuff…but their attitude is just…. ‘i cannot be bothered’ 😮
  • Adrian Hewson
    17 August 2005 at 21:17
    Not being funny NIk, they make a lot of different good products, from full blown road signs to smart little aluminium spacers, have been using them for about 3 years and do between £3-4K per month with them, they are good, they have the odd dodgy emplyee but for the products they are worth working with
    Regards Adrian
    17 August 2005 at 21:22
    i totally agree adrian….they are a brilliant company, but it was just the guys on the phone…when it happens just the once fine ‘dodgy employee’ but several times…. 🙄 thats the only reason why i have never phoned them back…. 😀
    17 August 2005 at 23:44
    Try them again Nik – They’re a pretty good company I would say
  • Cheryl Tissington
    18 August 2005 at 00:06
    Hi Nik
    I had some road signs from them a few weeks ago. I must agree that some of the staff on the phone were absolute rubbish.
    I used their website and sent an enquiry by email. They came straight back to me in the morning with a quote. Their prices are really good. It’s well worth another try.
    Cheers,
    Cheryl
    18 August 2005 at 20:55
    thanks adrian phil & cheryl…..for convincing me i will contact them again tomorrow 😀 vince i’ll put the drawing on hold for now 😉
    thanks again
  • Brian Little
    18 August 2005 at 21:14
    YEH nIK IVE GOT TO SAY IVE HAD THAT EXPERIENCE TO WITH THEM …I WAS SPENDING 3 GRAND OR THERE ABOUT WITH THEM …….AND THEY COULDNT BE ARSED
    BRIAN
  • Carrie Brown
    18 August 2005 at 21:22
    We use Ashby a fair bit and I must admit have never had any problems with them. 😀
    18 August 2005 at 21:30
    we also use Ashby and not had a problem, apart from the fact they always want to fax you a price ,doesn’t work for us we don’t have a fax they have got used to it now and send an e-mail 😛
    18 August 2005 at 21:56
    We use Ashby products a lot. Looking forward to seeing this illuminated lump of rock!? Is it close to electrical point?
    18 August 2005 at 22:22
    quote DaveRowland:
    you might not see the ‘stone pillars’ i hopefully will be doing… 😀 and as for it being close to an electrical point…customers worrie not mine 😀
    18 August 2005 at 22:33
    😛 i know it is customer, but Solar panel’s could be hidden on top etc. and then use a combination of magical lo-power LED’s design to create something nice and appealing..
