Home Forums Printing Discussions Uniform Printers can a cadet be good enough to run as a basic plotter?
  • can a cadet be good enough to run as a basic plotter?
    Posted by Kenny Ramsey on 29 November 2006 at 16:55
    I was hoping someone could give me an opinion or perhaps a pic showing how good a Cadet is as a basic plotter.
    If I buy a cadet, I will still use a plotter but I’d like to know if the Cadet will be capable of cutting 10mm text for example. Basically I’m trying to suss out how much work I would still need to out source.
    Many thanks
    Kenny
    Marekdlux replied 19 years, 1 month ago 3 Members · 3 Replies
  • Alan Wharton
    29 November 2006 at 17:08
    i dont have a cadet although i get a fair bit of digital work and sub it out, what i can say is iv seen the cadet in action and it cuts the same as my plotter including small fonts, cadets a expensive vinyl cutter though at 8k 🙄
  • Kenny Ramsey
    29 November 2006 at 17:11
    quote Alan Wharton:
    Very true. Wouldn’t want it spending too much time doing that
  • Marekdlux
    29 November 2006 at 20:37
    A cadet is a re-branded Versacamm, right?
    If so, it would work as a plotter. I use ours all the time. It does cut a lot slower than our other plotter though, but if you are not in a rush then it works just fine.
    -Marek
