Home Forums Vinyl Cutter Discussions Roland Cutters CAMM 1 pro 1860 perforated cutting problem
  • CAMM 1 pro 1860 perforated cutting problem
    Posted by James Beavon on 28 March 2009 at 19:44
    my plotter has recently started perforating its cut lines when cutting out at a certain angle.
    when it does this i can hear the blade housing shudder and it skips over the vinyl creating a perforated cut.
    ive took the housing apart tightened up the screws and had a good look at it and think that either one of the rollers has worn down too much or the spring had lost some of its tightness causing a certain ammount of play in the housing.
    has anyone else had this problem or knows how to eliminate.
    thanks
    Mike Fear replied 16 years, 8 months ago 4 Members · 5 Replies
  • John Childs
    28 March 2009 at 19:54
    How’s the cutting strip?
  • James Beavon
    28 March 2009 at 20:04
    hmmm
    i thought it may be the cutting strip as it is pretty worn, will replace this first.
  • James Beavon
    4 April 2009 at 16:22
    Nope thats not it.
    im sure its the small wheel that moves the blade housing up and down, it looks replaceable too as it has a clasp on it.
    ive tried searching the net but cant find one.
    hmmm any suggestions
  • Otto Peltonen
    4 April 2009 at 17:27
    I had the same problem a while ago and it was cured when I changed a brand new blade holder.
  • Mike Fear
    4 April 2009 at 17:53
    First thing I would check is the bearing in the blade holder – mine started doing this, and it was because the blade wasnt spinning to the correct angle, and was being dragged through the vinyl.
    A liberal coating in WD40 had it working perfectly in no time.
