Home Forums Printing Discussions Uniform Printers Cadet wasatch sent2print occasionally prints zoomed in??
  • Cadet wasatch sent2print occasionally prints zoomed in??
    Posted by Elena kalispera on 1 August 2010 at 07:53
    Hi guys I’m hoping you will be able to help. When using Wasatch 6.7 did it with 6.6 also I send image it goes to print on my uniform cadet sp540v sometimes I get the print image printing massively on page like double the size? it happening randomly and sometimes does not happen at all for ages??? the other issues is that sometimes it wont print at all??
    any help appreciated.
    David Rogers replied 15 years, 4 months ago 3 Members · 5 Replies
    1 August 2010 at 14:45
    possibly left the crop box on when resizing
  • Elena kalispera
    1 August 2010 at 15:16
    Hi Chris, no I thought that but I checked and its not. Was thinking a software or hardware issue.. I’ve done the following]
    clean encoder
    checked files and setup
    check and reset ip setting and config
    checked cables
    checked update on 6.7 the latest
    Only thing I can think of is the fact I’m running an i7 64bit system with vista. there seems to be a lot of floors with vista 64bit and with the latest i7 processors with certain software?? Will keep looking tho thanks for your input.. 🙂
  • David Rogers
    1 August 2010 at 21:05
    Used to get this from time to time when I did one of two things (when I first got my Cadet).
    Came from me messing about with the control panel after sending the job to print (eg. adjusting the temperatures) and also not having the correct ‘live’ profile for the job being sent. Can be something as simple as the the media width being wrong.
    Always ensure you follow a basic procedure when first running:
    Machine on.
    Machine reads media.
    THEN START WASATCH.
    SETUP.
    then RIP, PRINT…
    Also make sure your Cadet firmware is up to date….takes a couple of minutes to do.
  • Elena kalispera
    1 August 2010 at 21:32
    CHEERS DAVID I hope your right as I must admit i do play with temps before print and after file rasterised. so could be will make a note cheers
  • David Rogers
    1 August 2010 at 22:09
    quote Elena kalispera:
    The ONLY button you can press after you send to the printer is PAUSE when the ‘HEATING’ notice comes on to just proceed.
    Make NO adjustments to the printer in any way once you press ‘OK’ in Wasatch -don’t even open up the TEMP menus to take a look.
    Once it’s printing it is possible to make a few changes – but personally I wouldn’t.
    I lost a LOT of prints in the way you described when I first got my Cadet by adjusting the TEMP after sending it – and before printing started.
