Home Forums Sign Making Discussions General Sign Topics Bridge height clearance signs
  • Bridge height clearance signs
    Posted by Warren Beard on 1 December 2009 at 20:59
    Hi All
    From what I have read there is some controversy regarding wording for these types of signs. Has anybody done any Minimum / Maximum height clearance signs to hang under bridges etc?
    Do you state "minimum height" or "Maximum Height" ?
    If the height is 2230mm what will the dimension need to be that are stated on the sign? I believe you have to allow a certain amount of "extra" space so in this case say less 50mm, so height would be 2.18m or 7′ (or both)
    who knows, anybody? want to share 🙄 :lol1:
    It’s for a private estate with an archway drive through access so not on public roads.
    Warren
    Chris Wool replied 16 years, 1 month ago 7 Members · 9 Replies
  • 9 Replies
  • Graeme Harrold
    1 December 2009 at 21:05
    Sample layouts
    for private access, prob do actual minus 10-15%.
    1 December 2009 at 21:13
    you need to determine the maximum height for the width of the vehicle with an arch, and mark the position where the vehicle will pass under the centre at that height
    I dont know what clearance is standard, but if its on a private estatem I would err on the safe side and allow 100mm less than the actual height,
  • Warren Beard
    1 December 2009 at 21:23
    It needs to be a wide swinging panel and yes as Peter says will be hanging at the lowest point of the arch which will be the side points at the top of the upright brickwork.
    I have this height which is 2230mm but need to know if it should read "Minimum Clearance" or Maximum Clearance"? I’m not sure 100mm will be necessary as it is actually higher due to the arch. I’m not sure it will make a huge difference but thought I would ask.
    Warren
    1 December 2009 at 21:28
    Warren just say height limit, (xx) then no confusion with max and min
    1 December 2009 at 21:48
    warren just imagine you are driving your van towards it.
    what info do you want to see and how presented.
  • John Harding
    1 December 2009 at 22:22
    quote :
    Duck 🙄
    1 December 2009 at 22:55
    skip the english…. could be a foreigner, possibly someone from SA!
    regulation all the way.
    1 December 2009 at 23:22
    Back to your original question Warren – I believe it should phrased "maximum height" – anything else is ambiguous
    2 December 2009 at 00:06
    quote :
    NO HIGH ROOF TRANSITS unless flat tyres
