Home Forums Software Discussions Corel Software box luton wrap cold weather
  • box luton wrap cold weather
    Posted by Colin Bland on 4 January 2010 at 09:32
    we have a box luton to wrap in the next week or so – only the box section so all flat panels, the box part of the van is grp so shouldn’t be any real problems except I cant get the van in my unit so will be working outside.
    With the current temperatures I am worried about the cold application – do I need to worry? Has anyone done similar?
    any advice would be welcome
    thanks
    Colin
    David Rogers replied 15 years, 12 months ago 5 Members · 8 Replies
  • 8 Replies
  • Gareth.Lewis
    4 January 2010 at 11:04
    Hi Colin,
    I can’t give any advice but I’m hoping the advice will be that things should be ok, at least the same as when applying normal (non digi) vinyl in the cold on (cold) flat panels. Maybe just use a heat gun (carefully) to wake up the glue a bit after application.
    Here’s hoping I’m not wrong……..
  • John Childs
    4 January 2010 at 12:11
    Not ideal circumstances Colin.
    The only advice I can give is to get as much heat on it as you can.
  • Chris Windebank
    4 January 2010 at 13:07
    or heat in it. Is there a way to heat the panels from the inside if it is single skinned. Used a space heater before to help or a couple of oil fed rads on for a couple of hours
  • Colin Bland
    4 January 2010 at 13:49
    Thanks for your advice weather looks to be getting colder over next week as well Doh!!
    Heating up from the inside may be a good way of doing it
    Colin
  • John Childs
    4 January 2010 at 14:36
    quote -Colin-:
    But not if it’s insulated. 😀
    Inside heating helps in single skin vans, but I think it would take a lot of heat and a long time before it made much difference through a box van with walls of, what, three quarters of an inch thick?
  • Chris Windebank
    4 January 2010 at 14:53
    True John, the only ones I have done are for removal companies and have always been single sided, even then it takes time
  • Colin Bland
    5 January 2010 at 00:44
    Thanks for help
    have spoken with the client and they are going to wait till the weather warms up a little.
    Looks like they may have a long wait !
    Colin
  • David Rogers
    5 January 2010 at 08:28
    Or you could phone round to find a friendly haulage garage / warehouse that will let you do it indoors.
    Throw them £50 for the ‘rent’ – all three parties are winners.
