Home › Forums › Vinyl Cutter Discussions › General Cutter topics › Blade Setting
Blade Setting
Posted by Garrie on 18 October 2006 at 11:23Hi,
Anyone else find setting up a new blade a big pain? I hate doing it, its job a never look forward too 😥
Garrie replied 19 years, 1 month ago 3 Members · 4 Replies -
Hi Garrie,
When replacing a blade have the point just sticking out a smidge so you can hardly see it and reduce your pressure a bit. Cut some simple squares, circles or fine text, it shouldn’t mark or cut through the back of the backing sheet, if it does you have too much pressure. On a new blade I find that weeding should be clean and an easy task.Cheers John
Garrie
I’d recommend a smart knife – no fuss at all and cheaper to get reground than buying a new knife.
Haven’t looked back since getting a couple.
Russ
Hi John,
Thanks for the advice, I know how to setup the blade, I just hate doing it, I never get it spot on first time.
Interestly I’ve always had the blade set just to mark the backing paper slightly.
Russell, though blades do sound a good idea 😀
Hey,
outa 61 people so far I guess I’m the only one who has a nightmere setting up a brand new blade (<(
