Home Forums Vinyl Cutter Discussions General Cutter topics Blade help!!!… please help!! (doing my head in)
  • Blade help!!!… please help!! (doing my head in)
    Posted by Alan Harrison on 29 April 2007 at 18:29
    I have a creation pcut 630and am in the process of setting it all up..
    I am adusting the blade to the correct depth and it cut’s the material about right, but it’s so close to the material that when it moves it scratches the rest of the vinyl (when it’s travelling to another cut)
    I have tried to adjust the blade depth, but then it dos’n’t seem to cut the material properley.
    Alan
    Garrie replied 18 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Richard Urquhart
    29 April 2007 at 18:38
    Are another p-cutting problem !!
    if the blade is not out of its holder to far and the vinyl is flat when cutting then i cant think of any adjustment (user one ) that could be changed as this would be set at the factory, is the blade just out of the holder ??
    29 April 2007 at 18:49
    quote :
    blade holder set to low ?
  • Alan Harrison
    29 April 2007 at 19:07
    Sorted that problem now another one..
    when it cuts letters for instance… it dos’nt go completely round the letter (it leaves a small bit of material uncut) It’s like I need it to overlap onto where it started..
    If that makes a bit of sence to you, please help..
    Alan
    29 April 2007 at 19:20
    quote :
    what was that then
  • George Kern
    29 April 2007 at 19:28
    quote Alan Harrison:
    Alan
    Hmm, is the parts that are not getting cut too close to the edge of the material possibly? Maybe you could post the file you are trying to cut so others could take a look at it to see if the file has any problems?
  • Alan Harrison
    29 April 2007 at 19:57
    It’s even if I cut standard text..
    Alan
    29 April 2007 at 20:59
    Sounds like the blade offset is wrong. Your plotter supplier should be helping you with all this.
  • Garrie
    30 April 2007 at 08:38
    Deffo blade offset is set incorrectly.
    What software are you using? You can’t set the blade offset in the PCUT itself it has to be done via software 🙁
