Blade depth & Offsets
Blades come in a variety of angles depending on the cutter model and what you are cutting. ie. 30, 45 and 60 degree blades are common. The default standard blade angle for cutting regular vinyl will differ between manufacturers – some use 45 degree and others 30 degree etc. What is common is that you will usually have to use different blade angles for thicker materials (sand blast or reflective) – these should be listed in the plotter manual, or try one of the many 3rd party blade suppliers who should be able to tell you.
More to follow…
