Home Forums Printing Discussions Roland Printers Black Over-Spraying
  • Black Over-Spraying
    Posted by Noel Moore on 15 January 2014 at 12:29
    Hi Guys.
    Recently my Roland SP-540V has started to spray Black as "Splashes" on print jobs. Also, where Black meets White, there is a black over-spray unwanted "glow" effect.
    Please see attached PDF where I have circled in RED the problems.
    I tried cleaning. I have also cleaned the Data Strip.
    Any help would be gratefully received.
    Regards,
    Noel
    [/img]
    Simon Elliott replied 11 years, 10 months ago 8 Members · 12 Replies
  • 12 Replies
  • Stafford Cox
    15 January 2014 at 12:50
    The drops on the page could be a wiper. I don’t think I could blame the overspray on that though. Looks electrical, maybe a faulty printhead?
    Stafford
    15 January 2014 at 17:17
    blobs as staford says looks like you may still have a bit of fluf on the head = small lines just after print.
    over spray may be static or if old the head on the way out.
    whats the test print like
  • Noel Moore
    15 January 2014 at 17:24
    Hi Stafford & Chris – thanks for your replies.
    The print head is only months old and the test print is good.
    Noel
    15 January 2014 at 18:07
    what materials have you printed on recently,
    did you or a tech fit the head was it good after the head was fitted.
  • Gareth Morgan
    16 January 2014 at 08:39
    I had the same issue after fitting a printhead myself, turned out to be earth strap on the print head, not sitting in the correct place.
  • Stafford Cox
    16 January 2014 at 09:59
    quote Noel Moore:
    Noel
    That’s good. Although not necessarily the final word. It could be cable, carriage board, or something a lot simpler. It just looks electrical to me and needs further investigation. If you do your own maintenance, I would try swapping head positions to prove or disprove my wild theory :lol1:
  • Noel Moore
    16 January 2014 at 10:02
    Thanks – I will try swapping heads and see is the problem persists.
    I will post updates.
  • NeilFox
    16 January 2014 at 18:56
    I may be way off with this, but a number of years ago I had a roll of material that I kept getting static shocks from. It was on my old SP540V. When I was printing it I got a ‘ghosting’ over spray on the edge of the defined lines.
    Another thing that I noticed was that the material had difficulty being advanced through the printer, kept giving me feed motor errors.
    I dumped the roll and never had a problem again. Never used the material again either. JAC.
  • Clive Martinez
    16 January 2014 at 22:45
    whem my machine started overspraying in black and the test print was good, the only cure was. a new print head.
    I noticed that when I printed fast at low quality. and. doublr print the results were better… but eventualy I had to bite the bullet and get a new head..
  • Ryan Gallagher
    17 January 2014 at 09:01
    Have you checked that the head height is set to low? If i forget to lower it after printing a banner or similar, i get a bit of overspray.
  • Stafford Cox
    17 January 2014 at 09:19
    quote Ryan Gallagher:
    Very good point!! I forgot to suggest that 😳 :lol1:
  • Simon Elliott
    31 January 2014 at 12:49
    I will second the comments above about static on the material and the head height. Both problems i’ve experienced.
    I have exactly the same problem by sadly mine is due to requiring a new head. May I ask if it was hard to change the head? Ive read about ‘rank numbers’ but can’t see anywhere in the settings where I would input it?
    Any help appreciated. thanks
    Simon.
