Home Forums Printing Discussions Mimaki Printers best profile on CJV30-130
  • best profile on CJV30-130
    Posted by John McNickle on 22 February 2018 at 08:30
    I was hoping someone has found the best colour match profile for printing on the CJV30 printers, i use the spandex/metamark & avery profiles the most but all 3 are way way different in colour output, some cant print a good grey as they are more purple on output, if anyone has info on a better profile could you please give me a heads up
    thanks
    Stafford Cox replied 7 years, 9 months ago 2 Members · 2 Replies
  • Jon Marshall
    22 February 2018 at 09:16
    I would recommend printing off a pantone chart on the vinyls you use in your preferred profiles and then set up your artwork based on that..
  • Stafford Cox
    22 February 2018 at 11:34
    This varies so much between media’s and RIP’s. Theoretically there is no such thing as a generic profile that will print everything. In practice there are a few good all rounders that give satisfactory results on many media’s.
    Which RIP are you using? The problem with printing grey is that most RIP’s will try to produce it with 4 colours. You could try turning off ICC profiling all together (it will over ink and other colours will likely not match) or use a ‘mono print’, depending on which RIP you’re using. If you’re using Rasterlink, you might be stuck with what you’ve got.
    Stafford.
