Home Forums Software Discussions Signlab Software Basic signlab problem, Help needed?
  • Basic signlab problem, Help needed?
    Posted by Peter Greener on 12 June 2011 at 16:17
    Hi All, when i go to cut some text in signlab ( the text looks as its written ) the plotter cuts it out upside down and the wrong way round
    Does anyone know what settings I have wrong please?
    Pete
    Peter Normington replied 14 years, 6 months ago 5 Members · 12 Replies
  • 12 Replies
  • Brian Hays
    12 June 2011 at 20:17
    How does it look on the preview in Signlab? maybe your cutter is set to mirror rather than it being the software.
  • Peter Greener
    12 June 2011 at 20:43
    in signlab it looks as it should when you write text IE from right to left etc
    The plotter is a Roland camm 1 960
  • Peter Greener
    12 June 2011 at 20:44
    If i type TEST fr example it looks correct
    when it cuts it says TSET and its also upside down???
    In signlab it says its going to cut TEST
  • Brian Hays
    12 June 2011 at 21:24
    There is an option that mirrors stuff on the cutter, can’t recall exactly as I don’t have much experience with Roland’s these days. Do you have the book for it. Should be a very simple fix if you know what buttons to press (hopefully!)
  • Brian Hays
    12 June 2011 at 21:36
    Manual here makes no mention of it…
    http://www.signcutpro.com/files/man/rol … 60+910.pdf
    What version of Signlab do you have?
  • Peter Greener
    12 June 2011 at 21:41
    Yes ive been through the roland manual twice and tried every setting in the book without any joy
    Will try again with a fresh set of eyes tommorow
    Thankyou for your help aswell as its appreciated
    Pete
  • Peter Dee
    13 June 2011 at 07:50
    Select CUT/plotting defaults, then make sure that "Mirror" is NOT selected.
  • Frank Droog
    13 June 2011 at 13:15
    Like Peter says, make sure Mirror is UnChecked in Cut/ Plotting Defaults.
    Also make sure Axis Swaap is unchecked in Cut/Plotting Deafaults
    Also make sure Rotate is set to 90 on the cutter itself.
    With rotate ste to 0, the cutter cuts along the width of the vinyl, not the length
  • Brian Hays
    13 June 2011 at 19:20
    If mirror is checked in the setup it will be reversed in the preview? which it isn’t.
    13 June 2011 at 22:13
    I had a similar problem with older versions of signlab.
    unistall and then reinstall the plotter,
  • Peter Greener
    14 June 2011 at 09:24
    Hi and thanks to everyone for the help, I checked everything and after losing lots of hair and screaming like a girl at the pc and plotter I sussed out the problem!
    The plotter was set-up correct, it seems that in signlab that one of the little origin settings was wrong so it caused a conflict which made everything look correct on the software but told the cutter to turn the image round and also mirror it
    Neither mirror or transform etc were ticked in signlab.
    A real pain but the good news is that its now back working as it did originally
    Its a shame that for some reason when I asked if anyone had a user guide / manual etc for signlab 5 the forum admins deleted it as I could really do with the manual as mine was lost??
    Pete
    14 June 2011 at 12:08
    peter the manuals for signlab, are not that comprehensive, everything covered is actually in the signlab help files. pity though I chucked out my siglab 5 manuals only the day before you asked for them!
