• Posted by Tim Hobbs on 1 May 2007 at 08:30
    Hi Guys
    We have just bought an eyeletting machine and are making our own banners.
    Does anyone know a good method for hemming without a sewing machine?
    I have seen this banner tape advertised, wondered if anyone had any good advice on this. It seems that it could be difficult to turn the edge of the material.
    Tim
    Tim Hobbs replied 18 years, 8 months ago 6 Members · 12 Replies
  • 12 Replies
    1 May 2007 at 08:37
  • Tim Hobbs
    1 May 2007 at 08:41
    Thanks Rob
    I can’t seem to get into that link though, telling me that it’s for members only. My membership is up to date I think, or am I being thick.
    It’s been known!!!
    1 May 2007 at 08:55
    ahhh sorry mate… i seen tyhe gold membership tag and thought you had access…
    video access is only available to "Gold Plus" or "UKSG".
  • Tim Hobbs
    1 May 2007 at 08:58
    No worries mate.
    Can’t afford the upgrade right now.
    Perhaps someone can just give me a quick tip on the edging bit.
    Tim
  • Peter Munday
    1 May 2007 at 12:03
    Tim I have just started selling banners with no hemming, but I put a second piece of banner material behind the grommet to add extra strength, It seems to be ok, had a few up for a while now.
  • Gavin MacMillan
    1 May 2007 at 12:10
    If it’s short term no hem is really needed. Longer term we use tape. Apply the tape to the edge and (1edge at a time) and fold over. Takes a wee bit of practice but remember it’s a banner and doesn’t need to be perfect so even your first attempts should be fine.
    G
    1 May 2007 at 12:14
    I have also made printed banners without hems, without any problems, but if it was for long term use and in a place subject to wind, and without any backing(wall or fence) then I would hem for that extra bit of strength.
    Hexis sell double sided tape for banners, although I have some I have not tried it yet. 25mm and 50mm
    Some people have had a problem with the material curling if not hemmed, I have only used the heavyweight digital banner from trounce for printed banners, no problems.
  • Gavin MacMillan
    1 May 2007 at 12:16
    Should have said, we use the 3m 25mm banner weld – it’s been thoroughly tested!
  • Peter Munday
    1 May 2007 at 12:23
    The only problem using hem tape is that if you roll the banner up it wrinkles quite badly and looks unprofessional.
  • Gavin MacMillan
    1 May 2007 at 12:57
    I don’t see it as that much of a problem. Our banners we buy in are not exactly perfect on the edges and then you have the white stitching. It’s a bit of a compromise maybe, but the profit margin is much better! And we have never had any complaints. Let’s you turn banners around very quickly as well.
    G
  • Martin Oxenham
    1 May 2007 at 15:02
    We’ve done several lately with Power tape on printed banners.
    Its a flexible plastic strip that sticks to the back of the banner and you eyelet right through. It gives a stiff rigid edge to the banner and helps keep it straight. The only down side is its a bit too rigid.
  • Tim Hobbs
    1 May 2007 at 17:27
    Thanks everyone for your kind help.
    I think that it’s experiment time!
    Tim
