Home › Forums › Printing Discussions › General Printing Topics › Art Canvas Recomendation
Posted by Martin Oxenham on 11 February 2007 at 16:18Can anyone recommend a good art Canvas for digital printing.
I’ve tried the one from B&P and the one from Europoint but both seem to
give very dull washy and faded looking results. I have tried printing both sides. Am I doing something wrong, profiles didn’t seem to make any difference.David Harvey replied 18 years, 10 months ago 13 Members · 23 Replies -
Martin I also have the same question tried several canvases, they seem flat and non vibrant, spandex do two that I would like to try, but you can’t get a working sample, and the least you can buy is 10 meters 🙄
Hi All
Try Hexis I have had some good prints off my Versacamm with their media.
Best wishes
Alex -
lots are flat and off colour, lots require profiling and profiling measuring tools.
did all the profiling etc. Dave what do you get good results on ??
we use TSSC15 from All Print Supplies, it printed well on the Roland and it prints well on the JV5
quote Martin Oxenham:Can anyone recommend a good art Canvas for digital printing.
give very dull washy and faded looking results. I have tried printing both sides. Am I doing something wrong, profiles didn’t seem to make any difference.Martin, the print result will depend on the quality of the canvas. If you have Frederick stretch artist canvas there, it prints a very good result.
You’ll see one side has little specks of cotton freckles (for want of a better term) the other side should be white.
Slow your speed right down, perhaps half of the speed you use for normal printing. If you are printing photos, RIP them as RGB not CMYK.
You get a good result using the overlay feature on some RIPSs too. It basically lays down 2 coats of ink per pass.
The washed out look is nearly always a sign it is printing way too fast. I’d be confident that if your heads are going slow enough, that will not be an issue.
In terms of profiling, I have not done anything in this regard to my printer. I use the profile for my hi quality vinyl material, and it works fine. Both have similar levels of white, and it works well for me.
Don’t forget the liquid laminate to finish, as the dust will settle on the cotton ‘thread’ and it will look like cr@p when it gets dirty/dusty. It also lifts the colour on the print, giving it a deeper stronger colour.
Hope that helps.
Martin,
Like Darren, I’ve had quite pleasing results using the All Print Supplies material printing with VersaCamm, Cadlink RIP and a generic Roland profile.
The pictures I printed were from a digital camera (studio portrait) and my own digital camera (copy of an oil painting). In both cases the dark colours and skin tones printed quite well compared with the originals, the studio portraits were particularly good, helped by the controlled lighting. My own suffered in that respect.
There are couple of very easy changes that one can make in the Cadlink RIP which will produce much cleaner colours, especially yellows, reds and oranges, combined with Shanes idea of slowing the head speed and applying a liquid laminate would probably produce significantly better/different results.
I have also tried the Hexis product and all the above applies.
You might also contact MetamarkSteve
we dont do allot of canvas to have tried various suppliers, but i have used, and did just the other day… grafityps canvas. cant fault the stuff to be honest.
Been through the whole process and tested loads…..
I think the best is the gloss from Kernow Coatings……
With the Oce coated a very close second…..using a Verde Solven Satin profile although I think there is now one for the Kernow [Oce] available…..
I do prefer the vibrant colours on the gloss although they reflect the black etc……use force black thingy to stop any green tinge.
andrew i have tried to get test bits of the kenow canvas after i saw it at the show last year as i thought it had a lot better colours than others i have seen but non to be found ?
Will print sample if you want Chris…maybe try Oce very similar…
Chris
this is a link to their web page there is actually a sample request button in the menu.Kev
europoint were ment to be distributing the kernow stuff but last told nothing doing and i used to have a account with kernow but they only want to sell a pallet load at a time now.
what inks you runningchris
quote :T550SGAC Solvent Gloss Artist’s Canvas 550µ
thank you kevin and andrew is that the stuf
Chris
europoint got me a sample of Hydosol sent out a couple of months ago no problem, came direct from KernowKev
i have asked kernow for sample if nothing happens will ask europoint again thanks for you input
kernow sent sample and very impressed good strong colours when they are meant to be i will be ordering some as so far the best i have seen
will just have to adjust the white point a bit in PS
Chris
Chris,
let me know which profile you end up using…..
allprint done a wonderful job on there profiles for the eco sol max inks soljet pro2
apsLD3810g 720 dpi 8 pass bidir is for a gloss white vinyl but worked well here and compared against the same photos printed on my epson 9500
has given me the confidence to move forward with some oil paintings to copy.Chris
I use the Universal from B&P and after a nice man came and set up my profiles for it correctly the colours are really good, the bright colours on the canvas are as good as the satin paper.
I print with a Resolve with activasol ink. If you want a sample, I’ll always post one to you.
David
