Activity Feed › Forums › Sign Making Discussions › Vinyl › Applying Vinyl to Walls
Posted by Nicholas Gormley on December 10, 2009 at 6:01 pmHi, has anyone any tips on how to prepare a wall to apply vinyl on it in a house?? Will MD5 be ok to do it in aswell?? Any help would be brilliant.
Nicholas
Steve Underhill replied 14 years, 5 months ago 7 Members · 7 Replies -
Depends a lot on what you are trying to put it onto as well and how well the walls coverings have been applied to start with. The other problem you may have is the application tape taking paint off the wall when it is removed. If its a print then you may be best to apply it without any application tape.
Your application strength is only as good as the surface you are sticking it to.
Poor surface = Poor strength. If in doubt do a test piece in a corner where any accidents wont be seen. -
are we talking a brick wall or plaster board type finish?
For Brick, as has been said, Hexis do one and so do WmSmith 3M http://www.williamsmith.co.uk/
Robert Horne Don’t do a brick covering one, but do do the Oracal wall coverings vinyls which i think is really smart and comes with a re-positional adhesive. comes in many nice colours too like pastel apple green, peach, chocolate brown etc
Andersons also do a wall mountable vinyl, ask for Louise, and see will sort it out for you
Do you mean a normal painted/plastered wall?
If you do, stick the vinyl straight to it with medium or low tack tape and roll back gently, not peel like you would a sign, it sticks really well. I have a floral design in my shop with strands less than 1mm thick i fitted with no problem, where you see the birds there up top the strands measure 0.5mm
this is painted plaster on brick, painted by myself so know its ok.if your’e unsure paint the wall with a mix of PVA and water, this will help adhesion of the paint. (dont put the PVA mix on if its already painted lol)This is the design in my shop, its cut from grafityp matt exhibition vinyl.
