Anyone using Vion 5100 Material
Is anyone using the Vion 5100 media (Grey adhesive and air flow)?
I really want to like this media, I love how glossy it is but I’m having nightmares with it.
It doesn’t seem to hold in place where I have trimmed? I first noticed this on a bonnet of a Peugeot Partner. The following day there were fingers along the front of the bonnet, I didn’t go around the seam, I just trimmed it 5mm from the edge with cutting tape. It also looked like it wanted to lift / curl around the recess panels where I had trimmed.
There is no tension on my laminator so I am ruling this out. I managed to fix the fingers by going over the areas with a heat gun (a lot) and it seem to have stuck in place.
I now have another job I have to fix, the lines trimmed between the back doors and the sliding door along the side has failed, the vinyl has lifted off the panels where I fed the material around the panel after trimming.
Not had this issue once with other material and two issues in two jobs, the supplier have been great helping me sort this but I wondered if anyone is using this material?
