Home Forums Sign Making Discussions Neon, LED, Lighting Anyone recommend the best adhesive for fabricating Foamex ?
  • Anyone recommend the best adhesive for fabricating Foamex ?
    Posted by Martin Manley on 3 March 2013 at 11:00
    Need to fabricate some large (1 metre high) letters in Foam PVC. Normally i would use Tensol 70 to stick it all (Foam to foam) but these might need something a bit heavier duty. Have trawled through ‘net for data sheets but not much forthcoming on sticking. Any ideas?
    Martin
    Martin Manley replied 12 years, 9 months ago 6 Members · 6 Replies
  • David Rogers
    3 March 2013 at 16:04
    cyanoacrylate adhesive (superglue) works amazingly well on foamex.
    Another and it leaves no residue is a chloroform / (di/tri)chloromethane base as it melts the material where it’s touching other material (doesn’t evaporate)…but evaporates on exposed surfaces.
    sold as light duty acrylic adhesive
  • Simon Worrall
    3 March 2013 at 19:07
    For foamed PVC I use adhesive that is sold for bonding pvc pipes. Available in all DIY stores.
    Couldn’t tell you a brand name offhand. Go to the plumbing section.
    Simon.
  • Glenn Sharp
    3 March 2013 at 22:31
  • Mike Grant
    3 March 2013 at 23:13
    quote DavidRogers:
    Sorry Dave but chloroform does not stick PVC. I gave away 4 demi johns full of chloroform as it didn’t stick foam pvc. I bought in some other glue as I wanted one adhesive for perspex and pvc, only to find they had stopped making it as it is carcenogenic. Kicking myself now as I can’t get chloroform any more.
  • Kevin Flowers
    3 March 2013 at 23:16
    I use mitre fix fast, strong and super quick
  • Martin Manley
    4 March 2013 at 16:46
    Thanks guys – all good advice. The fusion stuff from grafityp seems expensive but probably works out cheaper than it’s equivalent weight in mitre fix.
    Will post pictures of finished job…
    Martin
