Anyone creating contour paths in Illustrator for Flexi?
Hi everyone,
I’m having real problems with flexisign pro and contour cutting. The contour cutting feature in flexi doesn’t give me the cut lines that I want. Image below gives an idea of the cut line I am after for my simple test print…
I’ve found some info on other forums from google searches, with what I believe should be:
- create new swatch named ‘CutContour’, making sure its a spot colour
- put the contour path on its own layer, unlocked and above the print layer
- add CutContour to the Custom Colur Mapping
When I send the contour job to the cutter it doesn’t respond at all, which may be down to the cutter being set up on usb and not serial (its a Liyu which are currently being imported by Andy at Mistatees).
Is this the method others use for using custom contour paths from Illustrator? I am looking to start cutting motocross graphics, which will require custom contour paths.
Any help would be really much appreciated.
Thanks,
Richard
